Peaking at lower boost ever since i installed my o2 dump and LICP
Old Sep 7, 2013 | 10:25 PM
mrm95's Avatar
Well im tuned on 91 oct at 26 psi on my stock IX turbo. Last night I installed a LICP as well as a muse o2 dump. Anyways, afte rlast night I did a few pulls and notice I only peak at 23 psi now. I was thinking maybe since the wastegate is dumped now that since that might be causing better flow of the wastegate gases that boost might not be spiking at much. ( I have a Grimmspeed 3 port EBCS by the way) I just hope its not a boost leak. Any ideas?
Old Sep 8, 2013 | 09:51 AM
EvocentriK's Avatar
Possibly increased the VE of the engine with the mods giving you lower boost. Boost is pressure generated between the turbo and the engine as a function of how much air the engine can flow. If you are tuned on a given WGDC% then increase the amount of air that the engine can flow, the turbo cannot pressurize it to the same level anymore.
Old Sep 8, 2013 | 10:38 AM
meckert's Avatar
you may want to hold off on the "pulls" until you get that thing tuned--those are some pretty big changes and your only seeing one portion of the results in the psi. I'll bet your a lot leaner as well.
Old Sep 8, 2013 | 11:34 AM
djdnav's Avatar
Did you install the housing using the stock gasket? Because that's a big no no
svt_lightning01
21
Mar 12, 2019 07:02 PM
Slow208
Jan 19, 2017 02:12 PM
awdordie
11
Aug 18, 2011 12:42 PM
awdordie
Apr 30, 2011 09:44 PM
jnut24
Mar 27, 2011 09:03 PM
