exterior WG flapper arm length?
Old Sep 14, 2013 | 08:01 PM
rstchris's Avatar
Can someone measure center to center on the exterior wg flapper arm for me? Oem turbo and any aftermarket internal wg turbos. Trying to get an idea of the best length so the wga will preload it strong but will still fully open.
Old Sep 15, 2013 | 12:05 AM
egis's Avatar
sparky knows best.seriously pm him.
Old Sep 15, 2013 | 06:17 AM
94AWDcoupe's Avatar
was measuring this the other day. OEM, HKS, garret all have different lengths. I was planning on tweaking the HKS and garrett with longer arms. really should be setup on bench to maximize.
tool I use
Old Sep 15, 2013 | 09:57 AM
rstchris's Avatar
Can someone pop their hood and hold a measuring tape up to it please. I don't have an oem mhi turbo to compare mine to. I think its the reason my fp 25psi wga only makes 17psi fully preloaded.
Old Sep 15, 2013 | 10:13 AM
Evoardo IX's Avatar
It's not as easy as popping the hood and measuring.... most of us still have the OEM shield, thus making it impossible to even see the arm... I will adjust preload next week, will measure then and let you know... hopefully someone can help you before.
PS: Seriously, PM Sparky, he knows a lot about wastegates and some other thing lol
Old Sep 15, 2013 | 10:38 AM
90zcrex's Avatar
Really no need to measure, http://store.forcedperformance.net/m...Info_wastegate
Old Sep 15, 2013 | 04:49 PM
egis's Avatar
8.5" from the center of the hole(flapper side) to the wg canister.i measured the rod only.E9 turbo,kinugawa wg.prealoaded by Boostin performance a week ago.
Old Sep 15, 2013 | 05:08 PM
rstchris's Avatar
Sorry, maybe I should have been more clear. I'm looking for the outside flapper arm measurement. Not the wga rod length. From where it comes out of the turbine housing to where the actuator rod hooks up, center to center.
Mine is a hair over 3/4" on center.
Old Sep 15, 2013 | 05:46 PM
egis's Avatar
yah it's 3/4" on my car.
Old Sep 15, 2013 | 07:16 PM
rstchris's Avatar
TY sir, what turbo is that?
MHI E9 or aftermarket?
Old Sep 16, 2013 | 06:51 PM
egis's Avatar
Originally Posted by rstchris
ty sir, what turbo is that?
Mhi e9 or aftermarket?
e9
Old Sep 16, 2013 | 06:56 PM
rstchris's Avatar
Problem solved. Extended it to 1" on center and makes 24psi on the actuator, no controller.
simons3z
13
Feb 3, 2017 03:52 PM
black_beauty
Nov 17, 2014 07:10 PM
fightex
13
May 14, 2012 01:06 AM
Wayne99gsr
Northwest Region
16
May 26, 2011 08:25 PM
