Noise, sounds like something is loose..
As I am driving, say for example 30mph and I let go the gas something is making noise underneath the front wheels. It seems as if the exaust system where the catback meets the high-flow cat, maybe the gasket is completely worn and metal rubbing on metal ?...but when I am back on the gas, the noise disappears...I am currently on Comp Clutch kit with light flywheel..
I would just jack the car up and check along the exhaust system if its rubbing anywhere you will be able to tell because the metal will be shiny. If no then you can check you steering system, have either a helper shake tires/ steering wheel and anywhere that moves oddly can be worn, also does the sound go away when you turn one direction or the other (if no this rules out wheel bearings). Check for loose bolts. Other than that stuff I would just say its clutch chatter from the flywheel, the vibrations usually associated with that can either be absorbed by oem motor mounts sometimes, or ignored if you have poly mounts and just chalk the vibration up to the stiffer mounts. But because its on decel only I would guess clutch chatter but also a guess without looking at your car so take it with a grain of salt.
My front sway bar was hitting my down pipe. Couldn't see it with the wheels off the ground because the sway bar moves with the suspension. Had to look at it with car on a flat rack.
same issue
im having the same issue but at around 55-60mph. if I let off the gas I get a noticeable vibration under the car (seems to be around the transfer case area). at the same speed, if I throw the car in neutral...no vibration. I've had my exedy triple plate clutch for a over a year and never had this noise. can anyone help?
Evo__Lee
Oct 4, 2018 10:23 PM
king_cas
Jul 15, 2016 08:57 AM
king_cas
Jul 9, 2016 10:13 PM
va1k0s
Mitsubishi TC-SST Discussion
May 19, 2016 07:57 AM
Turbo Ghost
Sep 1, 2014 12:26 PM
