Quick question!
Old Oct 20, 2013 | 08:38 PM
ILoveAWD's Avatar
Quick question!
So I'm running a aftermarket turbo its a borg warner ant it only oil cooled. my question is the coolant lines that use to run to the stock turbo can i just loop a line to those plugs and not have an issue? thanks again for the help
Old Oct 20, 2013 | 08:48 PM
galantman03's Avatar
You can either loop them, or block them.
Old Oct 20, 2013 | 09:06 PM
ILoveAWD's Avatar
ok thanks for the info bro really helped out i was just curious cause i didn't want to loop them and they cause some kind of coolant temp issue. Thanks again!
Old Oct 20, 2013 | 09:09 PM
no prob man, if you look at them one comes from the lower part of the water neck and the other feeds from the water pipe in the back. I personally welded the water pipe closed, and then cut nipple off the water neck, drilled it out, welded a 1/8npt bung on there for my water temp gauge.
Old Oct 20, 2013 | 09:43 PM
ILoveAWD's Avatar
if i had thought about it i would of welded it befpre i dropped in the motor .
grim~
Jan 22, 2016 06:05 PM
Tekniq
Dec 10, 2015 03:46 PM
rn520
Mar 26, 2015 04:57 PM
pwdrtoastman
Jul 4, 2010 06:36 AM
Blue Evo 8
Aug 26, 2006 11:56 AM
