Crank walk rebuild advice
Old May 30, 2014 | 08:16 AM
O0oDC's Avatar
Originally Posted by fallenauthority
Ouch 5w-20 in a 4g63? Nothing like water for oil
could that have caused it? The machine shop says it must have been starving for oil
Old May 30, 2014 | 08:30 AM
LetsGetThisDone's Avatar
The thin oil might hurt the turbo. But nothing else would really care. The oil pump is high enough volume to keep everything alive.
Old May 30, 2014 | 08:40 AM
Roadrunr's Avatar
Buy the looks of the Main Bearings, you had either debris or low oil pressure.
Replace your oil pump assembly. including the housing. [ https://secure.buschurracing.com/cat...ad6eeb14131d3f ]
Also check your oil cooler and lines for debris. If any is present, I would replace it also.
Don
Old May 30, 2014 | 11:53 AM
TurboTylerIX's Avatar
Don
Agreed! you MUST replace the oil pump and housing assembly. With all the shaving you had, your aluminum oil pump housing is guaranteed to be grooved/scored and the pump will not make the proper pressure and flow anymore. Mine was and I had way less shavings than you.
Also, definitely replace the oil cooler. There is no way to flush it out and be guaranteed that you got all the debris out. The cooler lines you can flush out. I sprayed a bunch of greased lighting in mine and let it soak for a while, then I blasted them out with my garden hose and nozzle. I repeated the process for good measure. of course make sure they are dry before you reinstall them.
Old May 30, 2014 | 03:07 PM
O0oDC's Avatar
So I just spoke with the machine shop. The block, crank, and pistons are completely shot. So now I have 2 projects. A 2.4l build + fp black, and a sweet 4g63 coffee table.
Old May 30, 2014 | 03:22 PM
Hahaha! coffee table! I was thinking the same thing for mine, but i think a V8 block would make a much better table base unfortunately...
Did you have to take your block/crank to the shop or did they tell you by looking at pictures. I still need to find out if my block is trash or not. Not sure how to find out?
Old May 31, 2014 | 02:08 PM
2slow4now's Avatar
WOW just checked out your pictures.
Did it grind through the thrust bearing? It looks like it did with the thrust bearing shard in the oil pump pick up and the grinding on the girdle.
Sorry everything junked out but yeah a 4g63 coffee table or end table would be a good next life for that engine. two I have one sitting in the garage I want to do the same thing with.
Another idea I had was cut it out on the end of the block and insert a mailbox in it. Would be cool with a built looking block, head, intake, exh manny, and turbo as a mailbox. The only problem would be the doped up scrappers trying to steal it.
Old Jun 1, 2014 | 10:01 AM
Ted B's Avatar
The previous owner used 5w20 the day he sold it to me, so I assume he used that.
Wow.
Nothing invites metal-to-metal contact like using a thinner oil than what the engine was designed to use. I feel confident in making the assumption this is the sole reason why your 21k mile engine failed in a manner that is rarely seen here, and with symptoms that are hallmarks of what happens when oil viscosity is too thin. It's too bad that you're having to pay the price for what was an inexplicable, critically poor decision by the previous owner.
Old Jun 1, 2014 | 03:09 PM
rgonyer's Avatar
5w20 was never used in the car in the previous owners possession. How do I know? I am the previous owner. Mobil 1 10W30 was exclusively used in the car from the day I picked it up at around 4k miles.
Old Jun 1, 2014 | 03:13 PM
Ted B's Avatar
Thanks for making the correction. In that case, the oil itself wasn't the issue.
Old Jun 7, 2014 | 08:30 AM
O0oDC's Avatar
Thanks for clearing that up rgonyer. A container of 5w20 was found in the trunk, I assumed this was used in the recent oil change. I have no idea what could have caused this now. Thanks for the help guys
Old Jun 7, 2014 | 09:35 AM
AutoXMRIX's Avatar
Dang....I would just buy a completely new bottom end if this happened. It's just less headache to go and rebuild it. May not be cost effective...but less headache.
Hope you get the EVO back on the road soon.
Evo47
Jan 21, 2017 11:00 PM
Coxor
14
Aug 24, 2013 11:02 AM
AKW89
Feb 9, 2012 05:58 PM
WickedIXMR
Jan 13, 2012 10:17 AM
CrawlinTBSS
Dec 22, 2011 09:15 AM
