Revs holding while at WOT
Old Jan 24, 2014 | 05:03 AM
Sykes's Avatar
At WOT it will rev to 4k (sometimes higher), pause for a second then continue to rev. Doesn't always happen, only every two or three runs.
Any ideas what could be causing this?
my evo is mostly stock
Old Jan 24, 2014 | 06:37 PM
Sykes's Avatar
bump
Old Jan 26, 2014 | 02:42 PM
Pirana's Avatar
the dreaded throttle hang....I dont think anyone has it figured it out!
Old Jan 26, 2014 | 02:44 PM
Raptord's Avatar
Throttle hang doesn't happen while you're WOT. This isn't the same thing.
OP, does it feel like you aren't accelerating during that pause? Sounds like it might be the clutch slipping.
Old Jan 26, 2014 | 03:11 PM
Pirana's Avatar
Oh! right, sorry....
Old Jan 26, 2014 | 06:23 PM
ThatOneKid's Avatar
+1 for slipping clutch
Depending upon how heavily modded you are/ what fuel pump you're using it could also be fuel cut.
Old Jan 26, 2014 | 08:27 PM
Sykes's Avatar
^^ I'm running stock fuel setup and still make power at higher RPM after the pause
nope it holds at that 4k for that second. even if i got WOT still.
Old Jan 26, 2014 | 09:11 PM
detroit pistins's Avatar
Do you have a log of the issue?
Old Jan 26, 2014 | 09:22 PM
Sykes's Avatar
no i dont sorry, i could take it for a run and try and get a video of it happening
Old Jan 26, 2014 | 09:33 PM
shrtstuff89's Avatar
Does the engine sound like its breaking up, bogging down, anything like that...that would cause momentary lack of acceleration?
Old Jan 27, 2014 | 12:37 PM
bbong's Avatar
knock?
Old Jan 27, 2014 | 03:49 PM
ThatOneKid's Avatar
Alright, next guess is that you're misfiring. What plugs are you running/ how old are they? Mileage/ how old are the wires?
Old Jan 27, 2014 | 04:57 PM
Sykes's Avatar
checked plugs and leads and they are fine. Plugs are only about 4k old, they are denso iridium's. Can't remember which ones exactly
EvilEvolution8
Dec 17, 2015 02:58 PM
Shinn
Jul 27, 2015 07:17 PM
butters149
Mitsubishi TC-SST Discussion
Aug 6, 2014 05:48 AM
plastus
Mar 16, 2014 06:46 PM
rstchris
Feb 20, 2014 05:12 PM
