View Poll Results: Which Oil Filter For The EVO?
Mobil M1 - 108
108
29.51%
Genuine Mitsubishi Oil Filter
233
63.66%
I Just Use the Cheapest One That Fits
25
6.83%
Voters: 366. You may not vote on this poll
Which Oil Filter?
Old Feb 26, 2009 | 06:47 PM
  #121
PC325xi's Avatar
I have a 2006 IX MR and the autozone website says that the correct mobil 1 oil filter is M1-110. but then for a 2003 VIII it says that the correct oil filter is M1-108. what is the difference between the two filters does anyone know?
Old Feb 26, 2009 | 10:20 PM
  #122
mchuang's Avatar
Originally Posted by otter
To any of you using Fram, STOP. You've got some learin' to do. Fram filters are the crappiest pieces of crap out there.
http://www.scuderiaciriani.com/rx7/oil_filter_study/
This is just one study out of many that points out how bad Fram filters really are. Stick with OEM or Mobil 1.
If you want proof yourself, buy a Fram and a Mobil 1 filter, get your hacksaw or dremel, and disassemble. It's easy to see why the Fram is so bad.
Just so you know the Fram filter for the 4g63 is the same as the oem honda filter. Both are made by honeywell, are stamped honeywell and look identical. As far as I know the honda filter does pretty well.
Old Mar 2, 2009 | 03:19 PM
  #123
Ichiban's Avatar
I was just looking at this the other day when I was at Autozone purchasing some unrelated parts. The M1-110 is taller and a bit wider than the M1-108. Seems closer in size to the "original" OEM filter.
Old Mar 2, 2009 | 03:21 PM
  #124
koey03's Avatar
OEM filters are cheap and reliable.....
i was wondering will oil filter really matter?
Old Apr 17, 2009 | 06:01 PM
  #125
speedypollard's Avatar
OEM everytime
Old Apr 17, 2009 | 06:07 PM
  #126
lem's Avatar
lem
i use oem. i just buy six filters at time so i don't have to go to the dealer everytime i have to change my oil, i buy my oil at walmart anyway.
Old Sep 14, 2009 | 12:53 PM
  #127
boostedscooby 5's Avatar
am ready to change my cars oil since am having the oil pan removed because of a leak . what is the part number for the oem oil filter.
oil leak at turbo return line
https://www.evolutionm.net/forums/ev...need-help.html
Old Nov 11, 2011 | 09:27 AM
  #128
2004EvoVIII's Avatar
Sorry for the thread revival here - just thought everyone should know:
I have a 2004 Evo VIII and the guy at my mitsu dealer gave me the part number for the Oil filter needed for the Evo. It is MZ690072. There are only two different filters that Mitsu uses, this being the "skinnier" of the two. The other one is a fatter one and not called for on the Evo. I believe the part number was said in one of the previous posts and it is part number MZ690116.
Old Nov 11, 2011 | 04:02 PM
  #129
danextreyes7's Avatar
OEM every 2000miles and ngk plugs FTW!!!
Old Nov 14, 2011 | 03:34 PM
  #130
4g63Moon's Avatar
I think it also has to do with what kind and grade of oil your using. I use oem cus i run 10w30 real basic oil nothing crazy.
Old Aug 23, 2012 | 07:30 PM
  #131
coollol123's Avatar
I Can't find a OEM Oil Filter for my 02' OZ.. Help? -______-
Old Aug 23, 2012 | 08:00 PM
  #132
Piro Fyre's Avatar
You can go to Napa and ask the guys at the counter for a part number.
Old Aug 24, 2012 | 08:12 AM
  #133
Corbin09's Avatar
Has anyone tried out the Bosch filters? I am running one now, and havent had any issues.
Old Aug 24, 2012 | 10:32 AM
  #134
boostedwrx's Avatar
I havent used OEM since they stopped making the MD356000. Napa Gold/WIX for me.
Old Aug 24, 2012 | 11:21 AM
  #135
kaonashi's Avatar
I've always used Wix, or OEM as this guy said, even on my vette
