2 muffler catback?
Old Mar 15, 2014 | 11:56 AM
lv05evo's Avatar
Lightbulb 2 muffler catback?
After looking at this thread:
https://www.evolutionm.net/forums/ev...t-exhaust.html
I thought for my set-up I can't do away with the cat. So why not try to add a second muffler(small diameter round obviously) to the catback. Now I don't know how to fabricate so this might not be possible, but if one can add say a small Burns or magnaflow round muffler next to the driveshaft that should work right? Fabricators please chime in. Or better yet if you have had a similar set up made, do it work on quieting down the exhaust.
Old Mar 15, 2014 | 12:34 PM
BriK's Avatar
It can be done; I've done it-- I have two mufflers between the cat and axle-back. The mufflers need to be pretty small and the one I have right after the cat needed to be angled down a bit to clear the driveshaft.
Old Mar 16, 2014 | 09:49 PM
lv05evo's Avatar
Did it work on quieting down the exhaust note? What mufflers did you use?
Old Mar 17, 2014 | 03:20 AM
17pstockcar's Avatar
Br will build you an exhaust with 2 mufflers. I was looking at it for a while but ended up going stm
Old Mar 18, 2014 | 11:29 AM
BriK's Avatar
It definitely did but it'll be hard to compare to other systems. I did a custom aluminum cat-back with a v-banded axle-back-- two mufflers between the cat and axle-back, then a third for the axle-back. This was without a cat. Since I did aluminum, I went with two aluminum Vibrant Race Mufflers, part no 12900.
run1206
Evo X Dyno Results
Feb 15, 2017 12:10 PM
BoosterX
Canadian
Oct 27, 2012 08:33 AM
FERNO
295
Jan 30, 2012 10:31 AM
mfr122887
Mar 16, 2010 07:06 PM
Kemist
For Sale - Part Outs
69
Jan 1, 2010 05:24 AM
