EVO 8/9 Synchrotech Carbon Synchros
Old Jun 15, 2016 | 07:05 AM
  #451
llDemonll's Avatar
Also curious....I bought these on the group buy a long time ago because I'd be rebuilding my transmission at some point.
Would love to hear what others have to say as well...don't want to get something installed that I have to go back and fix a year later
From what we'd heard from the honda people (which synchrotech has been around a long time) they all loved them
Old Jun 16, 2016 | 07:08 AM
  #452
kyoo's Avatar
Originally Posted by desiromeo812
Wanted to share my experience on these synchros.
I have a 400whp evo 8 myself. Bought the synchros about 6 months ago and had a local shop that specializes in evo's GTR's porsches rebuild my evo 8 transmission with these.
Fast forward about 3 months and for some reason 200 miles into the build, 3rd gear started grinding. took transmission out and replaced the synchro with an OEM one. The carbon synchro was completly burnt up and I figure maybe it was fluke or somekind.
Its been about 2,000 miles now and I grind going into 2nd from 1st gear anywhere above 6K. I figured maybe its my clutch (ACT full face), and I tried adjusting the clutch per Jacks transmissions video. Problem is still there, its actually started to present itself even going into 2nd from third on rev matching anywhere above 4K RPM.
I have not contacted Syncrotech yet when I replaced the 3rd gear since I figured maybe it was a fluke. I will be sending pictures and details of my experience to them as soon as I pull the trans again to see what is up with 2nd gear.
Fluid that gets used is redline cocktail
Car is 90% daily driven
400whp evo 8
I have done about 2 launches on this transmission since the build
All other gears shift perfectly at 8K or 8500 RPM.
what is the redline cocktail? you're not running any shockproof in there are you?
Old Jun 16, 2016 | 03:44 PM
  #453
Raptord's Avatar
Cocktail for CT9A's is 2 qts of MT90 and 1qt of MTL.
Old Jun 16, 2016 | 03:48 PM
  #454
kyoo's Avatar
why not just run mt85
Old Jun 16, 2016 | 08:10 PM
  #455
Raptord's Avatar
MT85 didn't exist back then when someone thought up the idea of making that cocktail :P
Old Jun 17, 2016 | 12:43 AM
  #456
desiromeo812's Avatar
shockproof only in the tcase boss!
Old Jun 17, 2016 | 12:45 AM
  #457
Originally Posted by mrfred
Thanks for sharing. Would be great if you could update your findings as they become available.
will do. BTW what clutch r u on?
Old Jun 17, 2016 | 03:39 AM
  #458
mrfred's Avatar
Carbonetic Full Blade. Awesome clutch if not abused. Easier than stock to modulate but holds 450 ft-lbs.
Old Jun 17, 2016 | 10:35 AM
  #459
AWD96's Avatar
I followed this thread before I pulled the trigger on the Syncrotech Carbon's. There really isn't any conclusive reporting in the 30 pages so far. Everyone just adds to the questions, so I'll do my best to make it plain. I have the carbon syncros. I am somewhat of a driver. My VIII in its current form is sitting in the 530ish whp area on STM's Mustang dyno for reference (750hp VD), the car on kill mode has trapped in the 140's going low 10's on a beat drivetrain making 650hp on the same dyno/setup.
When driving around town, compared to a 60k mile old trans that was beat to death, the carbon syncro's feel smoother, or engage nicer, than the previous used unit. Downshifts happen much easier, there is less direct effort needed on the shifter to engage the gear. Upshifting at high RPM's feels like it should. That's a little vague, but any time you bang a gear and it goes right in, that's kosher to me. I have shifted in the 8500-9k rev range and not had any issues. They are not magical in nature by any means, but I am satisfied with them.
I have had TRE do a few trans builds for me in my DSM days, and as far as quality of the shift I would say it is similar to that of a properly built OEM syncro transmission. Syncrotech has improved the tooth profile to aid in engagement of the syncro, so that has to count for something. These are still an oem style syncro, with carbon deposits where the syncro rides on the shaft to reduce friction. I noticed the trans needs to be warmed up to experience the best shift quality, and by warmed up I mean at least 5-10 miles of driving. It is notchy when cold, like most of our cars.
10.29@141 on a stock transmission with QM 8 leg with a 4.70 330' (for those that are 1/4 time savy). This trans almost never went into gear easily under 7k, causing a lot of transient response issues even with me forcing it, especially from 1-2 at high RPM's.
10.40@133 with a 4.30 330' with the carbon syncro build. Both 60' times were high 1.6's.
The main thing for me is how long will this last? So far I have alittle over 1k miles on the setup and 5 track passes at 530whp. They're supposed to outperform OEM syncros in every way and as far as that goes only time will tell.
If I did it over again, I would get them again for what it's worth.
Old Jun 17, 2016 | 06:11 PM
  #460
llDemonll's Avatar
that's all good to hear!
granted you're only one person, but still good to hear haha
Old Jun 19, 2016 | 08:06 AM
  #461
Turndown's Avatar
Veteran: Army
I'm currently getting some Carbon synchros in my trans thats being built at RRT Motorsports. I will also add some input once I get some time driving with them
Old Jun 24, 2016 | 09:48 AM
  #462
powerdriver's Avatar
Put a few hard track miles on the car.
So far, on redline cocktail mix, I'm impressed with the synchros. Shifts far better than the old transmission ever did. Had an Exedy twin carbon in the car back then, and it shifts better with an ACT clutch now, will update again after the RPS Carbon clutch is installed.
First fluid change looked relatively clean, no metal chunks but it has a glimmer of fine metal in the oil (Normal after a rebuild). Changing to Motul for the next race in a week's time. I'll have another update out shortly.
I usually end up killing a transmission every season, if this survives longer than a season I'll be *impressed*. It's a time attack car running big slicks and aero.
Closing thoughts
Would recommend, friend says it shifts better than a TRE OE synchro box, and before that he was in love with his transmission... until he drove mine lol
Old Jun 24, 2016 | 10:10 AM
  #463
mrfred's Avatar
How are you killing it? Lock out, shred a gear?
Old Jun 24, 2016 | 11:47 AM
  #464
Bent and discolored shift forks
impacted gears (not sheered, but not usable either)
discolored/bent synchros
bent shift keys
Most of my issues stem from getting the trans too hot.
Old May 12, 2017 | 10:02 AM
  #465
Synchrotech's Avatar
Hi Everyone,
We have had quite a few inquiries about making the EVO 8/9 MR 6 speed synchros. I will be starting a new interest thread for them and look forward to your input.
Thanks - David
