engine tick
Old May 2, 2014 | 04:33 PM
MP Evo's Avatar
engine tick
I noticed the one night driving home a ticking noise while cruising and my rpms were around 3k. When it's in neutral you really don't hear it but when you Rev you can hear it again. It's real loud and bad sounding in 1st 2nd at around 3k. If you hold car at 3k it gets loud and sounds like something is loose in head. I pulled valve cover and everything looked normal. I ordered new lifters and seeing if that's the issue or possible bad bearing in a rocker. Any other ideas what it could be besides rod knock :/ which I hope it isnt. Any help or ideas would be great. The motor is a buschur 2.0 with stage 3 head with gsc 2 cams.
Old May 2, 2014 | 04:37 PM
Faisalm's Avatar
Can't be sure without checking... But it's most likely one of those you mentioned.
Old May 2, 2014 | 05:36 PM
MP Evo's Avatar
Lifters or rockers you mean. I listened to YouTube and the rod knock videos seemed louder than my car.
Old May 4, 2014 | 05:03 AM
MP Evo's Avatar
Well changed the lifters and the sound still exists. Rockers were fine and the dual valve springs looked to be ok. That's basically all the top end components and compression was 150-160 across the board.
Old May 4, 2014 | 05:26 AM
Faisalm's Avatar
Did you drain the oil and look for metal shavings?
Old May 4, 2014 | 07:21 AM
Frew's Avatar
Best of luck Mike. My vote is to pull the head, that will let you see the valves, pistons, and cylinder condition.
Old May 4, 2014 | 08:46 AM
slowsrt4:('s Avatar
can you shoot a video of the sound? evos are noisy with their valvetrain
Old May 4, 2014 | 02:46 PM
MP Evo's Avatar
no I haven't done that yet.
Ichigo0Soul
21
Mar 26, 2014 05:43 AM
crankIT
10
Aug 29, 2012 03:44 AM
Solley
28
May 31, 2011 10:56 PM
06mr775
Jul 5, 2010 09:47 PM
evo unknown
12
Apr 5, 2009 03:44 PM
