TB porting - how to?
Old May 13, 2014 | 04:08 AM
TJung's Avatar
Hey guys. I have a plan to do porting for my stock TB and I have few questions:
-is it worth with non- ported intake mani?
-what gains should I expect?
-will I have some idle problems? How can I prevent for it?
-can I expect a better spool?
-what else should I do btw?
Thanks!
Old May 13, 2014 | 07:31 AM
Faisalm's Avatar
There's no point of porting a TB without porting your IM. Do both and expect better performance. If done properly you can see gains up to 20/20 or something like that.
You shouldn't have any idles issues whatsoever.
Spool may come in earlier or remain the same, but it shouldn't be later than it was before porting.
That's a very vague question. What else should you do in respect to what exactly? If you're speaking of power then please enlighten us with your goals in order for that question to be answered.
Old May 13, 2014 | 07:59 AM
TJung's Avatar
I reached my goals already. I just have one free tb and wanted to know what can I do when I will be changing my tb. But if it doesn't make sense without porting im, I will buy one and port both.
Old May 13, 2014 | 09:37 AM
russianyuri's Avatar
Read up on some proting literature because you can definitely do more harm than good if you don't get the taper and polish just right.
Also make sure and be patient with it since you can't easily replace the metal you remove if you get in a rush.
Old May 14, 2014 | 04:31 PM
kpr's Avatar
kpr
Porting the Tb will do nothing. Now if your saying you want to bore it 65mm that'll help but you need a new throttle plate.
Old May 14, 2014 | 09:50 PM
TJung's Avatar
Yes, I meant that, not just porting. I can make it by myself
www.hartmet.sosnowiec.pl
Thanks for repiles!
Old May 16, 2014 | 06:53 PM
rextotherex's Avatar
go with a 65mm upgrade to see gains, and you want to port the IM to 65mm as well or else the air will hit the lip on the manifold.
Old May 16, 2014 | 07:43 PM
EvoTurboTurk's Avatar
Any gains to be had with porting the IM & getting the 75mm TB? Would you lose low end, but gain mid & top end?
Old May 16, 2014 | 08:43 PM
Faisalm's Avatar
I don't know if you can port the stock IM to 75mm, but the result would lead to low end loss and mid/top gain.
Erik@MIL.SPEC
365
Aug 29, 2017 12:59 PM
jmichetti
Mar 27, 2014 01:24 PM
yeayeaatou
36
Jul 6, 2013 11:08 PM
jaysonsyl
14
Apr 18, 2013 04:27 PM
xtina
Dec 31, 2012 07:55 PM
