Hole burnt into cylinder head
Old May 20, 2014 | 05:26 PM
4thStroke's Avatar
My divot was on my blocks deck, just outside of the fire ring. We tried to weld it but it wouldn't weld clean. I ground out the bad weld then lapped the block with a proper lapping block, some fine grit sand paper, and plenty of WD-40. It smoothed out nicely, although the divot is still very apparent. The head had a huge hole blown out of it. It was welded and resurfaced. I used copper spray on the new head gasket to help with any imperfections there might be left, but the motor has held up to plenty of abuse and high boost since. It was a lot of work, but its seemed to pay off thus far.
Anyways, find a reputable shop, they should be able to repair the head. I've seen some serious carnage repaired with some welding and good machine work.
Old May 20, 2014 | 06:02 PM
WikdEvo's Avatar
Thanks man. That's pretty reassuring to hear that. I've already got a new head so the block was my biggest worry.
Old May 20, 2014 | 11:45 PM
4thStroke's Avatar
As long as the divot is outside of the fire ring and the head, block, and head gasket are prepared correctly, you should be ok to go. You may be on borrowed time, but my repairs have been good for some time and I'll soon be pushing the motor hard once again in the near future, maybe as soon as this week. It's held up to varying pump gas and ethanol tunes from 26 to 35psi so far for a couple years now, so another 5psi should be good to go... it's the timing I'm worried about ad I need to be careful with that. The divot is far enough from the fire ring and I think it'll be ok. I expect something else to let go before the finger can be pointed at the divot'd block.
Old May 21, 2014 | 12:59 AM
BkzProblem's Avatar
Were you running e85 or 93?
Old May 21, 2014 | 09:49 PM
4thStroke's Avatar
I was on E85.
Old May 21, 2014 | 10:38 PM
galantman03's Avatar
Originally Posted by Tom Stout
I am in the same boat as you now. There is a divot in the head.
If I get the deck resurfaced the pistons will stick out .001 over the deck.
My dilemma with that is with a 9 HG will the extra thickness give me enough piston to valve clearance still?
The other option is that the machine shop has said he has repaired heads and blocks by drilling the hole out and tapping it and plugging with a very strong bolt made out of some special metal. He can then smooth it out and it will all be uniform. He showed us a few heads and you can't tell that it was ever plugged at all. Has anyone ever dealt with that?
Pics of the other cylinders coming tonight.
idk if anybody is aware of this, but you can repair it by using coldspray. Without going into the technical details, just think metal fragments sprayed at supersonic speed and at a certain temp, the metal powder is imbedded on the molecular level and becomes the part if that makes sense. Totally machinable and usable. Google RPM rapid city south dakota if you want to know more. They use it to fix aircraft panels that used to be just thrown away. Trust me I used to be the guy that threw the panels away
Old May 22, 2014 | 04:25 AM
WikdEvo's Avatar
I was on the corn as well. Waiting on injectors to come back from FIC so that we can get to the bottom of this.
Old May 22, 2014 | 11:43 AM
Joshthree6three's Avatar
ahh this truely does suck. I have gotten in the habbit of spending $80 a year plus another $24 for shipping to send my 2150s to FIC for cleaning and flow testing. The ~100 bucks i feel is like an expensive oil change, that takes about 6 buisness days to complete. down time sucks but the couple thousand dollar repair bill i would like to avoid.
I have no idea on the repair figures but I can imagine it will not be cheap. A happy fuel system = a happy driver. For the most part.
Old May 23, 2014 | 04:44 AM
slowsrt4:('s Avatar
Looks like it leaned out
Old May 23, 2014 | 10:21 PM
WikdEvo's Avatar
I was able to swing by my builders shop today and snag a few pics. The block turned out perfect!
Here are pics of the head.
Cyl #1
Cyl #2
Cyl #2 and #3
Last but not least #4
Old May 24, 2014 | 12:46 PM
KenPeak's Avatar
block fix looks amazing!
but that #4 cyl head pic doesnt like its going to seal very well.. you going with another cyl head?
Old May 24, 2014 | 02:37 PM
LetsGetThisDone's Avatar
Cylinder head looks like it's still needs to be machined...
Old May 24, 2014 | 02:38 PM
WikdEvo's Avatar
Lmao. Hope you guys aren't serious.. That head has a gaping hole in it.
I've already got another head games head going on the motor now.
Old May 24, 2014 | 05:43 PM
KenPeak's Avatar
good choice
WikdEvo
For Sale - Cars For Sale
May 18, 2016 08:38 AM
WikdEvo
Dec 11, 2015 01:41 PM
WikdEvo
Nov 28, 2015 11:34 AM
WikdEvo
Aug 22, 2015 07:43 PM
WikdEvo
Sep 2, 2014 11:47 AM
