Clutch Kit or just Clutch Disc?
I have a ACT Heavy Duty SSD and it has about 50k miles on it and will need a replacement soon. Is it recommended to get the kit again(which is like $730) or can I just get a Clutch Disk?
If I was able to get 50k miles out of a clutch and that same company recommended that I get a new clutch kit, guess what I would get a new clutch instead of just getting dics. 50k miles is a lot and I wouldn't want to reuse anything with that much milage and wear/tear on it. It's better to do it right the first time.
I got about 50k miles(not slipping yet from wot) on mine with drag passes and an autocross event. Act did me pretty well, sorry to hear your's went out at 10k. But sounds like getting a whole new kit is the way to go.
Yes the pressure plate and flywheel both get worn as well with the disk. The flywheel can usually be resurfaced as long as it's within spec. Everything else is not designed to be machined or reused.
2008EvoGSR
Jul 5, 2015 09:40 AM
