Speed sensor
Old Jul 24, 2014 | 06:29 PM
evoniners's Avatar
Speed sensor
So I replaced my clutch on my Evo ix the other week and now that everything is put back together I am getting a check engine light and my speedometer will not work nor will my odometer. I checked the code on my code reader and I am getting the engine speed sensor code. I have since then checked connections & pulled the sensor out to check for any damage, but nothing was seen. I just got through replacing my speed sensor thinking it could be something internal, but the speedometer still will not work. Does anyone know what that white gear engages in the transmission? I am thinking something broke there and is not turning the teeth on the end.
Old Jul 25, 2014 | 05:16 AM
evolve_VIII's Avatar
Do your reverse lights work?
Old Jul 25, 2014 | 09:26 AM
evoniners's Avatar
Yes. My reverse lights work. Does it run off the same circuit as my speed sensor?
Old Jul 25, 2014 | 10:12 AM
Its the same harness that connects to the main harness. Check the connector and the pins to make sure they didnt bend when you reconnected it. If you didnt disconnect it when you pulled the trans, you may have stretched the wiring.
Old Jul 25, 2014 | 12:30 PM
evoniners's Avatar
I checked the pins on the sensor as well as the connections on the harness, everything looks fine. I removed the harness before pulling the tranny so I know I could not have stretched anything. I am curious what the white gear on the sensor engages in the transmission. I think something might have broke there.
Old Jul 26, 2014 | 08:18 PM
evoniners's Avatar
Anyone know what the white gear on the end of my vehicle speed sensor engages with inside the transmission?
Old Jul 28, 2014 | 07:33 AM
It splines into the final drive gear ring for vehicle speed. Its weird how it would stop working after a clutch install when you disconnected and reconnected it.
Check all of your fuses to start.
Is the code a P0500? If so, the ECU is not seeing a signal back which would indicate an open in the wiring, poor connection, or no power at the sensor.
With the key on, check for voltage at the speed sensor and go from there. There should be power, ground and signal circuits. Search for a wiring pin out to check these.
bruce988jl
May 19, 2017 02:58 PM
BlackEvoV
Lancer Troubleshooting
Dec 8, 2015 06:26 AM
Sir_Lancer_Lots
Nov 22, 2015 06:43 PM
sno_evo
Oct 26, 2012 08:35 PM
TrappEvo355
Jun 9, 2012 05:43 AM
