When to change injectors and pump?
Old Mar 15, 2004 | 08:26 AM
ruthless evo 8's Avatar
Question When to change injectors and pump?
I'm putting on a turbo back exhaust, boost controller, fuel computer, intake. I plan on running 20-22 psi
Should I also upgrade the fuel pump and injectors, one of the two, or leave the stock equipment? Also what size injectors?
I've heard that the stock fuel pump fails under high stress but i lso heard it is rated high for a stock piece.
Old Mar 15, 2004 | 09:57 AM
bump
Old Mar 15, 2004 | 10:22 AM
gadsmevo's Avatar
I have heard the same for the stock pump. Apperntly it's a awesome piece until you stress it for an exteneded pierod of time. I have been logging my runs with a ODBII logger and I haven't been running lean according to my O2 but, then again I really don't trust the O2 reading.
Fuel pump is going to be my next mod just for as a safety net
Old Mar 15, 2004 | 10:30 AM
tama_mog's Avatar
Yes, to make a long story short, it's a general consensu to get a fuel pump for insurance....cheap insurance @ that...you don't want the stock pump to fail and all of a sudden go super lean....in terms of injectors, you have no need for them as of now with ur mods.
Old Mar 15, 2004 | 11:47 AM
thanks for the advice. It just saved me the trouble of ordering a part i didn't need. umm mabye cams will make up for the price.
Old Mar 15, 2004 | 01:27 PM
Coolguy949's Avatar
That wouldnt happen unless you were running a speed density standalone or removed the fuel cut. If your FP was to fail fuel cut would kick in detecting a lean mixture. But yeah, the stock fuel pump isnt something to place your confidence in when you're making big power. It has a tendancy to drop off fuel pressure at higher RPMs.
Old Mar 15, 2004 | 01:53 PM
jcnel_evo8's Avatar
fuel pressure sensor
Does the EVO8 computer have any sensor that sends it both the fuel pressure the rail is seeing, and the battery voltage the system is obtaining?
Does the computer adjust the injector pulsewidth based off of the voltage conditions, and/or the pressure regulation?
Thanks,
Joel.
Old Mar 15, 2004 | 05:18 PM
jcnel_evo8's Avatar
bumpitty
bump
Old Mar 15, 2004 | 05:57 PM
SinCityEvo's Avatar
These opinions are pissing me off. I am getting tuned next month and I was told to upgrade the pump unless you are completely stock. I have just a few bolt ons and it seems overkill for me to put it on, especially with people running pig rich after installing it and it making noise. I have not seen one single case of a pump failure that would warrant the new pump. I have bought too many things in life that have been a waste of money and I don't want to **** another hundred away.
Old Mar 15, 2004 | 06:17 PM
Speedlimit's Avatar
Admin Emeritus
Here is one opinion. I pulled this from a 5 page thread in the dynoflash forum.
https://www.evolutionm.net/forums/sh...threadid=66639
Speedlimit...
Originally posted by DynoFlash
I am advising fuel pump upgrades because under hgh stress conditions - e/g long dynp pulls at high boost or long repeated street pulls in high temp locations, I am seeing a large perentage of stock pumps which will suddenly start flowing significantly less psi of pressure as they get hot
The Walboro not only flows more, it is more consistant in high heat, stress situations
If you have a current dyno flash and switch over to the walboro pump your cvar will operate fine - however there is a slight possibility that it may run too rich in the high rpm range
This is especially the case for people who have had custom tuning and where we had to put in more injector duty cycle on top to maintain a/f ratio
The bottom line is i would rather have you put the pump in and possibly run a bit richer than run the stock one this summer - have it overheat and wind up with 13.0 a/f's and a hole in your piston fromj a failed fuel pump
I do NOT make $$ from selling pumps
I am ONLY posting this info so that my valued customers will not have any problems with their dyno flashed cars
When we suspect something - we observe it - - it is only after we CONFIRM a FACT that we made a warning or advisory
I have been suggesting fuel pumps for months - based upon my time with tuing turbo cars and genereal prudent advice
Now I have seen two pumps go bad in two cars in a row in 85 degree heat so I can tell you the pumps need to be changed
BTW - in both cases - the pumps were immeditely changed and the fuel flow was immediately retored
R0ME0
May 18, 2017 10:56 AM
I am me
33
Mar 21, 2015 11:03 PM
wooby99
Nov 24, 2009 11:18 AM
BlackOperative
Lancer Engine Tech
May 12, 2009 11:52 AM
Femi
AEM EMS
44
Feb 25, 2009 05:57 PM
