2.4L Question - Need help ASAP
Old Dec 5, 2014 | 05:23 PM
05EV08's Avatar
delete
Old Dec 5, 2014 | 11:17 PM
vaflyboi757's Avatar
It'll bolt right up.
Old Dec 6, 2014 | 02:51 AM
2001gslp's Avatar
It'll bolt up. However, I do believe you have to use the 4g63 oil pickup with any pan made for the evo. Don't quote me on it though. Sounds like that motor will be very torque happy!
Old Dec 6, 2014 | 08:00 AM
2006GSR's Avatar
Just buy the AMS/moroso oil pan. I have one on my 2.4 EVO and so do 3 of my other EVO budies.
Old Dec 6, 2014 | 08:21 AM
Ted B's Avatar
Originally Posted by 05EV08
I want to know if the Tomei Oil Baffle for the 4g63 will fit my block OR if I need to purchase the full kit here from AMS
The Tomei oil baffle is fine for a street car, but it doesn't do much unless the baffles are carefully bent (by hand) such that they just barely clear the crankshaft weights. All it does is pull oil off the crank to reduce windage.
The AMS setup is better suited toward a race car that will see high G-loading that can cause oil starvation.
Old Dec 6, 2014 | 01:58 PM
05EV08's Avatar
I will probably take the car down the track a couple of times to see what it runs but I don't plan on racing it. It'll be for daily duty.
Do you still recommend getting this or running nothing at all and just keep the stock setup.
Old Dec 6, 2014 | 04:07 PM
Ted B's Avatar
If you're going to remove the pan, the Tomei unit isn't a bad idea. I installed one myself. With the crank that close to the oil level, undoubtedly there is a fair amount of oil being thrown about. Just be patient while you're in there and bend those tabs such that they just barely clear the counterweights, and it will work as advertised.
Old Dec 7, 2014 | 08:26 AM
2006GSR's Avatar
Are you talking about the crank scrapper?
It won't work on a 2.4 with 100mm crank. You would have to gring the living **** out of it.
Old Dec 7, 2014 | 11:51 AM
05EV08's Avatar
So am I better off just not touching it at all? Yes I have the 4g64 motor. 2.4L with evo head.
Old Dec 7, 2014 | 05:51 PM
Fast_Freddie's Avatar
Veteran: Navy
There is a baffled oil pan, and crank scraper... which one are you talking about?
Old Dec 7, 2014 | 06:02 PM
05EV08's Avatar
This.
http://www.maperformance.com/4g63-sl...om-193048.html
SnowtaEvo
Sep 7, 2012 11:51 AM
Silv3r-eVo
15
May 16, 2008 06:53 PM
Silv3r-eVo
13
Feb 20, 2008 12:06 PM
my04rs
Mar 17, 2005 10:53 AM
