Worth the upgrade to 71HTA CHRA from stock 9 turbo??
Well, if your housings aren't cracked, it should be completely ok for them to do.
I wonder if they'd make one with a Xona center section with a BB
I'll shoot then an email. I'd love to have that particular green.
when the hell they make that o_O? why doesnt fp give a heads up on things lol. Also ive got two evo 9 turbos laying around, maybe I should spread them apart and see if the housings are cracked . both have like 100k miles though with no turbo timer =\
In Cali so would it be better to send in the turbo to FP so they can balance/refresh any bearings etc, and then send it back to bolt up?
I get I can do it at home but if they can check all the clips etc and make sure all is well, how much would they charge?
obviously would not want the antisurge housing now and I might have to keep OEM injectors too
This turbo really needs antisurge cover. If you want to use without antisurge cover, consider changing your turbine wheel to 9 blade to reduce chances of surges. FP won't have that, so you need someone who can customize for you.
e_kobz
76
Nov 13, 2021 03:33 PM
FS[Northeast]: New 71HTA CHRA w/ 9 WGA w/ 10.5 hotside
Evo VIII 4o1
Mar 3, 2015 06:22 PM
Michael @ FP
11
Sep 27, 2014 01:38 PM
