the amazing oil cooler delete kits
Old Jun 30, 2015 | 08:25 PM
  #136
Seancj's Avatar
Yes I know how it works.
And yes I am still right. It is a mettle spring it will get weaker over time due to use... Even spring steel will weeken over time that is all fact.
I am just offering some possible insight to why it would not seat all the way on an older used thermostat any maybe it is the resone some people do not experience failures and some do.
Old Jul 1, 2015 | 08:18 AM
  #137
03whitegsr's Avatar
Ha, so I didn't bother seeing how one comes apart as I just got a plug for a couple $. But one retaining ring and the whole thing comes apart and yet people are hacking them up instead?
I have a feeling that if that motor failed due to anything related to the thermostat...it was from oil contamination from cutting it apart.
Old Jul 2, 2015 | 06:19 AM
  #138
Seancj's Avatar
I completely gutted mine so it was just the copper cap and that is it. Works great.
And i agree just cutting it is a bad idea. Anything that can leave mettle contaminates is a bad idea.
Old Jul 3, 2015 | 01:32 PM
  #139
Piro Fyre's Avatar
Just making sure you know how it works. From the way you worded it, it sounded like it was operated with just the springs itself expanding and contracting.
Old Jul 27, 2016 | 04:52 AM
  #140
killercolt's Avatar
Omg. This thread so old but I can not believe that Buschur believed eliminatating the thermo valve can cause crank walk. Dave it was 100% coincidence that you had issue that that motor following your modification of the thermo valve. Please get a factory oil filter housing and trace the path of the oil flow. You will see that it is impossible to lose oil pressure by taking out the spring and valve and causing crank walk. I think the motor was already failing and you just happened to be the last person that touched it. It happens all the time. The last guy always get blame.
Old Jul 27, 2016 | 07:08 AM
  #141
ExViTermini's Avatar
Pulling up a year old thread for your first post, nice.
Old Jul 27, 2016 | 09:01 AM
  #142
LetsGetThisDone's Avatar
At least this is a good thread. And his post was more than "oh yeah, awesome!" lol
Old Aug 6, 2016 | 09:50 AM
  #143
Beaver2.0t's Avatar
Ok, so to delete oil cooler i need two m18x1.5 plugs and leave the stat in. Did i get this correct after 10 pages? Lol
Old Aug 6, 2016 | 05:31 PM
  #144
Simply_ct9a's Avatar
^^^ that's what I'm saying lol awesome read but after all 10 pages I'm still wondering what plugs are needed. I got the vw plug for the thermostat removal but what plugs do I use for the oil cooler ports?
Old Aug 6, 2016 | 05:33 PM
  #145
Beaver2.0t's Avatar
I ordered 3 plugs. 1 24x1.5 and 2 18x1.5 in stainless https://www.belmetric.com/shopping_c...m406ajn10b0342
Old Aug 6, 2016 | 05:58 PM
  #146
Awesome. Will be doing this before engine goes back into the car. Thanks
Old Aug 8, 2016 | 07:16 AM
  #147
killercolt's Avatar
I don't post a lot on here but I read a lot of the posts. This is one of those posts that make me questioned well known shops and their knowledge of 4g63t.
These pictures shows the thermo valve before and after boiled in water. You got to be crazy to not chop that springs out when plugging the oil cooler lines.
Old Aug 11, 2016 | 01:52 PM
  #148
Mauricio Evo IV's Avatar
I spun bearings two weeks ago. This is my second failure in three mothns. I think my oil cooler its dirty. Read other post, if you flush the oil cooler its not safe for using again. So I decide delete my oil cooler. My question is: How many people on this thred delete their oil cooler?
Im a littlevery confuse, but I understand that you need ONLY delete the oil cooler (with lines) right? Without touch the thermostat right?
Old Aug 11, 2016 | 01:54 PM
  #149
Beaver2.0t's Avatar
I deleted mine yest. Look at my post above with link
Old Aug 11, 2016 | 01:57 PM
  #150
Beaver2.0t's Avatar
