Idle problems
Old Mar 31, 2015 | 05:17 PM
Tykocoo's Avatar
Idle problems
Today my evo started idling weird at a light and continued to do so for the rest of the day. I have no idea what this could possibly be. I have an AME wide and gauge and when ever it started idling weird it also started running super lean. If anyone knows what's going on please help me haha thanks!
Old Mar 31, 2015 | 05:47 PM
i8acobra's Avatar
Sticky idle control valve on the throttle body? Vacuum leak from blowing off a hose? Had you just boosted hard?
Old Mar 31, 2015 | 05:51 PM
kaj's Avatar
kaj
does idle hunt up and down or just randomly go lean? any CELs?
check all vacuum lines.
Old Mar 31, 2015 | 06:36 PM
Tykocoo's Avatar
Itve got the idle set to 900rpm and when it goes lean it drops to about 600-500 and then it might bounce up to running super rich for a second but then as soon as I drive it sits where it's supposed to on the wide band
Old Mar 31, 2015 | 08:23 PM
kaj's Avatar
kaj
I'd start with testing for vacuum leaks. That's cheapest and easiest.
Does it go lean while cruising?
Old Mar 31, 2015 | 08:59 PM
Tykocoo's Avatar
No the only time it goes lean is when it has to idle for more than 10 seconds
Old Apr 1, 2015 | 07:04 AM
kaj's Avatar
kaj
do you have a way to datalog?
Old Apr 1, 2015 | 08:37 AM
1091x's Avatar
Having the same issue, check the EGR hose. That is a common source for strange idle. Check the IAC to make sure it moves fully.
Toxin
15
Mar 14, 2009 12:47 PM
Jorge T
Dec 2, 2007 06:30 PM
tt412
Jun 8, 2005 05:54 PM
eVoRox
Feb 3, 2004 05:56 PM
hawkmoon
Lancer Troubleshooting
13
Jan 26, 2004 11:36 PM
