NEED HELP~~~~Engine compression test
Old Apr 16, 2015 | 01:09 AM
ym827543327's Avatar
my engine compression test shown as below. So weried, any one can tell me why? Thanks alot
Old Apr 16, 2015 | 04:27 AM
meckert's Avatar
Cant judge from the info..How many miles? since all cylinders are within 10% of eachother wear appears to be even. With that said looks like all is well. I take it you notice no issues that caused you to look at compression--you just decided to check it?
Old Apr 16, 2015 | 04:48 AM
lostsoulsevo's Avatar
Is the motor built?
Old Apr 16, 2015 | 07:52 AM
Mecheng1993's Avatar
That's fairly low, but they're all within specification of each other. Start an engine fund and drive that one till it goes. You have no idea how long it may last and there are a ton of variables with compression tests.
Old Apr 16, 2015 | 08:34 AM
wreckleford's Avatar
Evo 9? Cams? What compression pistons?
Old Apr 16, 2015 | 12:34 PM
it has roughly 60k miles on it
Old Apr 16, 2015 | 12:35 PM
yea, its evo 9, just rebuild the long block, fully ported and tomei cams phase 2 and solid lifts, short block is stock
Old Apr 16, 2015 | 12:36 PM
just the long block been rebuild
Old Apr 16, 2015 | 04:19 PM
hutch959's Avatar
my evo 9 has about 105 on all cylinders... 272 cams (low cause the mivec thing)
makes 523, 430 on a mustang dyno.
uses just a little oil.
you are fine.
Old Apr 18, 2015 | 12:07 AM
Thx bro. I will check it out
Old Apr 19, 2015 | 10:13 AM
Jeff_Jeske's Avatar
I had Kelford 282 cams on my build and my compression was 110. I was so concerned that I swapped back to the stock cams and retested. The compression immediately jumped back to 130 just from a cam swap.
Old Apr 19, 2015 | 11:13 AM
kaj's Avatar
kaj
leakdown > compression test, so i'd say you are good to go.
Old Apr 19, 2015 | 12:38 PM
My car on s3's is 155 across all cylinders. Was 180 with stock cams
DuBBzEvo27
Jun 29, 2015 10:00 PM
ym827543327
Apr 6, 2015 07:56 PM
dambikeracer
57
Mar 14, 2010 07:43 PM
EvoDan2004
23
Feb 12, 2008 04:46 PM
evilevovegas
17
Dec 5, 2005 07:14 PM
