stainless injectors for e85
i'm looking to convert the car to e85. during race season, the car could be sitting for a month or so. and a few months over the winter. who make makes stainless injectors and what's the largest size
thanks.
looks like ID1300 are also all stainless internals.
http://injectordynamics.com/injectors/id1300/
Depending what power you're making, the ID1300's don't actually flow 1300cc. I think it was mrfred that did some testing that showed there were really close the FIC 1100 Hi-Z injectors.
I currently have FIC 1650 Hi-Z in my car, and they work very well.
500 whp on e85 is right at the limit or a little beyond for fic1100s and id1300s running stock 3-bar base pressure. i really wish someone would offer a true 1300-1400 cc/min high-z injector. with that said, fic2150s are an amazing injector for drivability. it took a bunch of work, but i now have my evo idling at 875 rpm at least as good as my fic1100s did. they're not stainless, but the point is that the bosch high-z injectors set a new standard for combining high flow with drivability. i've heard good things about the 1650s, but i haven't bothered to try them yet because dialing in the 2150s wore me out.
Remember what Tony of ID clarified on more than one occasion, that being much of the benefit of the Bosch EV7 injectors with respect to atomization, driveability, and fuel efficiency (and power) comes with running them at increased base pressures.
If one has upgraded his fuel system such that it supports higher pressures and has sufficient flow capacity, this issue is solved simply by raising the pressure.
Of course you know there is one limit - higher base pressure moves the pump(s) into lower flow territory. Depending on the boost level, it can be possible to reduce flow to the point of not being able to support the target whp. It was right at that limit for my E85 Walboro 400. It was running into the high pressure relief valve. With the right parts, it can be managed, but wanted to point it out.
The FIC 1650 Hi-Z's have been great on my car so far. It didn't take much work to get them idling at +/-2%. And then your low pulse width linearization table made them a touch more stable after tweaking the latency.
4b11slayer
Nov 2, 2017 10:40 AM
motocooney
Mar 28, 2011 10:00 PM
DaleRae
Jul 6, 2010 04:37 AM
