Evo 8 oil return line leaking
Old Jun 14, 2015 | 02:48 PM
Mottballa74's Avatar
Question Evo 8 oil return line leaking
Hey everyone I am kind of puzzled on my 03 evo 8 I have a 3586 turbo kit from ets, and my oil return line at the pan is leaking from the bolts, looks like have some seeping from the bolt holes I used factory bolts and the o rings plus thread sealer and its still leaking, what is some other options I can try or do,
thanks.
Old Jun 14, 2015 | 03:16 PM
LetsGetThisDone's Avatar
That always seeps a bit on me too. Next time the pan is off, I'm probably going to weld an AN fitting to the pan, and go to an AN instead of the stock tube.
Old Jun 14, 2015 | 03:17 PM
I don't have a stock tube its some aftermarket fitting but its seeping from the bolts like 1/2 quart every 2 days or so.. maybe less.
Old Jun 14, 2015 | 09:14 PM
doubleSUSTANON's Avatar
R u using the gasket? Also is it normal o-rings or the one in picture?
Old Jun 15, 2015 | 11:50 AM
Well, the stock one leaks on me, and I'm sure its the same reason your's does. Its a poor design. If you're using a bolt on AN fitting. Take the pan off, and have a AN fitting welded on. That will solve all of your problems..
Old Jun 16, 2015 | 05:49 PM
I figured out what it might be the guy RTV the pan instead of using the gasket which is probably causing the seeping from the bolt holes I will update when I try and fix this in a couple days!
Old Jun 16, 2015 | 05:50 PM
this will probably be the next thing I do.! Thanks!
Old Jun 16, 2015 | 05:51 PM
Found out there was just RTV not a gasket so I am getting this fixed someone this week, Thnaks
Old Jun 16, 2015 | 09:04 PM
The gasket still leaks...
EvODavO
Feb 28, 2016 04:12 PM
19DB794
27
Aug 15, 2013 07:17 PM
MarksIX
For Sale - Part Outs
10
May 31, 2009 03:49 PM
LetItBreath
Jan 6, 2008 07:40 PM
OtownEvo
Sep 24, 2007 01:54 AM
