Hole in Evo IX transfer case
Old Oct 18, 2015 | 09:38 PM
OZboyee's Avatar
So when pulling my motor we found this. I'm not sure if it was there before or I did it somehow splitting it. I've never driven the car as I got it with the blown engine we just pulled. My question is what's the best way to repair this? It's on the top so just some JBWELD? Or should I take in to get welded?
Old Oct 18, 2015 | 10:09 PM
LetsGetThisDone's Avatar
That looks like the bottom of the hole for the bolt for then tail shaft housing. Likely nothing to worry about.
Old Oct 18, 2015 | 10:22 PM
OZboyee's Avatar
It shouldn't be there though right? I mean can fluid come out there or could road debris get in through that hole?
Old Oct 19, 2015 | 09:27 AM
If fluid could come out, fluid would already have come out of it. If there is a bolt directly on the other side, it's just the bottom of the bolt hole, and nothing to be worried about.
Old Oct 19, 2015 | 09:48 AM
OZboyee's Avatar
Ill look on the other side, but i dont think its a bolt hole. Looks like its missing a chunk of aluminum. ha.
Old Oct 19, 2015 | 09:21 PM
I pulled my tcase tonight since it's going off to Shep and took a pic. It has the same hole, right where a bolt is on the other side.
Old Oct 20, 2015 | 08:45 AM
OZboyee's Avatar
Youre my hero.
if you dont mind can you confirm with Shep that its normal?
But clearly if you dont have an issue with it leaking or anything than I shouldnt either.
Thanks man!
Old Oct 20, 2015 | 08:48 AM
Yea, it's never leaked.
No problem
Old Oct 21, 2015 | 05:11 PM
Rolston12's Avatar
I was looking at my t case since it was out i have that hole too
Old Oct 21, 2015 | 11:16 PM
benIX's Avatar
Hey what's up man. My friend had a crack at the bottom of his trany and it was leaking a lot of oil. He put quick steal on it and believe it or not it stoped the leak. Now if you don't have a leak since its on top.I think it should be ok to use quick steal it's 6 bucks at Walmart. Good luck
Old Oct 22, 2015 | 08:07 AM
There is no fluid behind that hole. DO NOT go slopping quick seal crap all over your tcase.
Old Oct 22, 2015 | 09:55 AM
TheBoz's Avatar
Mine has that hole also, is does not leak from there. That is where they drill the receiver bolt hole. It will not leak from there.
Old Oct 25, 2015 | 09:03 PM
OZboyee's Avatar
this is good to know. thanks
EvoDan2004
14
May 24, 2013 02:18 PM
konstantinosIX
Jan 8, 2009 11:17 PM
oofastlineoo69
May 18, 2008 08:36 AM
Bloomie
Oct 21, 2007 08:14 PM
