Review: FP 71HTA
Old Nov 3, 2015 | 11:56 AM
KFC-AWD's Avatar
I recently installed the FP 71HTA with 84mm cover. I came from the Evo 8 with 10.5 housing. Turbo feels great, waiting for my 3port to be installed since boost isnt holding in upper rpms in 1st-3rd gear with stock
BCS. Here is a virtual dyno run in 3rd gear. I took it to ATCO last week, did 112mph, gained 26mph from the 1/8th to the end. Hoping once boost holds up high i will get another 2-3 mph out of my traps.
Old Nov 3, 2015 | 12:26 PM
LetsGetThisDone's Avatar
You should be able run more boost on 93 anyways. Turn that thing up to 25-26psi and hold it flat out the top.
Old Nov 3, 2015 | 12:57 PM
KFC-AWD's Avatar
Ya that is what I am hoping for, holding 25-26 psi on 93. I want to play with E85 afterwards :-)
Old Nov 3, 2015 | 01:33 PM
kaj's Avatar
kaj
Man, would I love that dyno sheet.
Old Nov 3, 2015 | 02:52 PM
e_kobz's Avatar
I love my E85/71hta setup. 450whp of fun
Old Nov 3, 2015 | 06:12 PM
tsitalon1's Avatar
Stop it, you're making me think about downgrading from my old JB Green to the 71hta with E85.
I hit 300wtq around 4k would love to have that around 3400
Old Nov 3, 2015 | 06:25 PM
KFC-AWD's Avatar
How much boost are you running on E85?
Old Nov 3, 2015 | 07:12 PM
kaj's Avatar
kaj
Jesus. That's more than my MAP 2.5 made.
Old Nov 3, 2015 | 11:25 PM
kikiturbo's Avatar
Really nice results...
You might want to add more preload to the WG and/or use stiffer WG actuator and not just rely on 3 port.. although 3 port is much better than stock..
Old Nov 3, 2015 | 11:29 PM
e_kobz's Avatar
30/31 and tapers to 27/28 by 7500rpm. Oh btw this was on stock cams. I have a set of S1's sitting on my shelf. But I might just sell them and do S2's instead
Old Nov 4, 2015 | 12:02 AM
kaj's Avatar
kaj
So 50whp more than a IX on stock turbo, 272s, and e85?
I dunno.
As for 30psi I wanted to do the same....But one small boost leak and my turbo is toast.
I do look forward to seeing what it will do @ 27psi/e85, though!
Old Nov 4, 2015 | 04:25 AM
e_kobz's Avatar
I dunno.
I did 390whp on the stock turbo on E85 at 30psi, but I had a leaky stock bov. When I swapped to the 71hta I upgraded to a Cobb DV with a really stiff spring
Old Nov 4, 2015 | 07:56 AM
awhit17's Avatar
I have a feeling you'll see a little more than you're expecting..here's how I did, 24psi spike holding a flat 23 out the top on 93oct, with an anti-surge cover too
Untitled by Alex Whitacre, on Flickr
Old Nov 4, 2015 | 08:00 AM
e_kobz's Avatar
Love this pump gas setup
Old Nov 4, 2015 | 08:03 AM
awhit17's Avatar
The car feels so great...my tuner was really impressed with how the turbo/setup did, considering we could give it 3-4 more psi out the top still. Tubular manifold coming soon so we will see how that helps things as well. This is such a great turbo, awesome powerband at reasonable boost, responds just as well as stock. Win win!!
