how much power u think i can make?
Old Nov 17, 2015 | 08:33 AM
moey124's Avatar
Hey guys.. tell me about this set up i just bought these stuff for my evo 9
GSC S2 274 274 BILLET CAMS
FP BLACK JOURNAL PORTED
MANLEY PISTONS STANDARD 9 TO 1
MANLEY RODS I BEAMS
STOCK CRANK
STOCK BLOCK
BILLET 70 MM THROTTLE BODY S90
VENTED DIP STICK BY STM
TOXIC FAB MANIFOLD
NEW GASKETS FRESH INSTALL.
aem meth kit but disconnected is it wise to reconnect?
how much power u guys think i can get ? I forgot mention got a six speed gear box. Limitations?
Old Nov 17, 2015 | 09:30 AM
GTijoejoe's Avatar
> 500whp on pump gas
Old Nov 17, 2015 | 10:07 AM
moey124's Avatar
Originally Posted by GTijoejoe
> 500whp on pump gas
SWEET !!!!!!! cant wait to dyno it
Old Nov 17, 2015 | 11:09 AM
cts4g63's Avatar
Bout three fiddy
Old Nov 17, 2015 | 01:18 PM
LetsGetThisDone's Avatar
> 500whp on pump gas
Not super likely unless pump gas is extra amazing in Jamaica. I would guess in 450-500whp range on 93 octane..
Old Nov 17, 2015 | 01:29 PM
Pal215's Avatar
High 500's Low 600's on E85.
By the way, if you have pistons and I beam rods, that's not a stock block even if the block casting is stock.
-pal215
Old Nov 18, 2015 | 06:22 AM
wreckleford's Avatar
90 Octane is our highest pump gas available.
Old Nov 18, 2015 | 07:10 AM
GTijoejoe's Avatar
Didn't see the location, you're not making 500 on that
Old Nov 18, 2015 | 10:24 AM
I make about 410-420whp on VD on ACN 91 octane. Depending on the quality of your 90 octane, you should be able to make about the same, or maybe touch 450 thanks to the larger turbo.
If you have the meth kit, and you have access to meth, I would definitely hook that. It'll help you hit 500whp for sure.
Old Nov 21, 2015 | 01:45 PM
moey124's Avatar
I have the neth kit but its un plug.. just scared of the meth pump of it fails then its a problem. Well i have to speak to my tuber regarding that. Its a stock block wid manley pistons and i beam rods and fp black. I hope i get some real good power. Will update you guys we currently working on the car.
Old Nov 21, 2015 | 05:27 PM
Setup the meth kit. It'll be fine. You can wire in fail safes..
turncoat
Jul 9, 2011 01:30 PM
Braydo25
May 12, 2010 09:54 PM
evoixmr1818
Feb 18, 2010 05:05 PM
EvowagonIX
18
Apr 27, 2009 05:41 PM
Big Turkey
10
Feb 9, 2005 02:38 PM
