GSC S2 cam with oem retainers?
Old Dec 20, 2015 | 09:04 PM
ayoi's Avatar
Hi guys,
Need help, im planning to install GSC S2 cam together with GSC beehive springs. My question are;
1. Do i need to change retainer too?
2. Can i use the OEM retainers together with S2 and beehive springs?
TQ
Old Dec 20, 2015 | 10:10 PM
LetsGetThisDone's Avatar
Yea, they'll be fine.
Old Dec 21, 2015 | 12:21 AM
Jp7's Avatar
Jp7
Originally Posted by ayoi
Hi guys,
TQ
I had my car set up like that for 5000 miles with no problems, will work fine.
Old Dec 21, 2015 | 04:57 AM
honda-guy's Avatar
depends how high you're going to rev your engine. if you're going to go through the trouble of replacing valve springs, why not pay a hundred more to do retainers also. the stock aluminum one are slightly lighter than the Ti ones though, but obviously the Ti are stronger.
i have a low mileage set for sale btw
https://www.evolutionm.net/forums/sa...retainers.html
Old Dec 21, 2015 | 08:54 AM
thestig0711's Avatar
My question is why not do them while you're in there already. Makes sense to spend a little extra cash and do it all at once. You can get away with what you want to do.
Old Dec 21, 2015 | 12:46 PM
STLEVOIX's Avatar
The retainers will break and cause lots of damaged. Done believe me? Check out this thread
https://www.evolutionm.net/forums/pr...d-project.html
Old Dec 21, 2015 | 01:08 PM
Hard to say if that wasn't or wasn't from using a beehive retainer on a standard spring. The springs he plans on using are beehive, and designed for the stock retainers. Those manleys are designed to go into a DSM, which comes with standard valve springs.
Old Dec 21, 2015 | 01:17 PM
STLEVOIX's Avatar
Are you running OEM retainers on your GSC springs?
Old Dec 21, 2015 | 01:29 PM
No, I bought the kit with retainers.
The spring rate and cams aren't what broke the retainers. It was using the wrong shape spring. This created more leverage on the retainer, which is most likely what broke them. If the stock retainers weren't safe, GSC wouldn't sell springs to use with them.
Old Dec 21, 2015 | 01:55 PM
STLEVOIX's Avatar
Do you have first hand knowledge that the OEM retainers work with GSC springs? Have you asked GSC if using OEM retainers is ok to do with their springs?
Old Dec 21, 2015 | 02:00 PM
Have you ever used google? Do you have first hand knowledge of google?
"The GSC 5039 Beehive spring is a factory replacement and will use your stock OEM retainer and valve seat to ensure an easy and inexpensive upgrade for your upgraded camshafts.
5039 Beehive spring pressure:
  • 1.56"=86 lbs / .450"=220lbs / .625"= Coil bind.
5039 Beehive Rev and Boost range (using an S2 profile camshaft set)
  • Max RPM: 8200
  • Max boost: 25 psi
5039 Beehive Max lift
  • Do to stock retainer max lift is 11.2mm at the valve or .259" cam lobe lift."
Old Dec 21, 2015 | 03:20 PM
SW20Mike's Avatar
Veteran: Air Force
I cracked 3 or so retainers using MAP beehive springs and oem retainers. Luckily I caught it in time and didn't drop a valve, promptly replaced with titanium retainers. Change them while you're in there, please.
Old Dec 21, 2015 | 03:37 PM
evo8426's Avatar
Oh great! Now I have a warm fuzzy feeling inside, I'm running MAP beehives on OEM retainers.
letsgetthisdone, too funny.
Old Dec 21, 2015 | 08:00 PM
ayoi's Avatar
TQ guys for the help,
Really appreciate it
Old Dec 21, 2015 | 09:02 PM
STLEVOIX's Avatar
  • Max RPM: 8200
  • Max boost: 25 psi
Ok smart guy, you win
OP, good luck
