rear diff issues after changing plates!!
Old Jan 20, 2016 | 07:42 PM
spitefire1's Avatar
Hey guys what's up..I re stacked my plates on my usdm evo 9..like the strict above says to did everything.im cure try going back to stock arrangement bc I don't like the lock up it doing..
Here is my first attempt with going back to stock arrangement. . Still making noises
Here is the second photo where it's still makes noise and sort of still locking up. Very slightly
Is their a way to where the plates need to be facing..any plates ot dick gotta go a certain way..I lost stock way..and need to figure this out.
Old Jan 20, 2016 | 08:14 PM
Piro Fyre's Avatar
What oil are you using?
Old Jan 21, 2016 | 05:17 AM
spitefire1's Avatar
Dia queen lsd oil
Old Jan 21, 2016 | 06:33 AM
Terror Rising's Avatar
How many miles did you drive it before concluding the noise was still too bad with the incorrect restack?
Old Jan 21, 2016 | 01:07 PM
spitefire1's Avatar
As soon as I backed out of garage started doing it
spitefire1's Avatar
Is their a certain way that the plates and it's have to face. Or direction?
Old Jan 22, 2016 | 07:50 AM
spitefire1's Avatar
rearranging direction of plates
I found this. I wonder if I put them back together like this will help.. anyone know about this apposed to the way I put them?
Old Jan 22, 2016 | 09:09 AM
LetsGetThisDone's Avatar
Maybe you should trade it in for a Prius? I hear those don't make any drivetrain noise..
This thread is funny. Literally the exact reason the US got a watered down version of the car.
Old Jan 22, 2016 | 11:14 AM
ReaperX's Avatar
The only thing that would cause an issue when you properly stack the clutch plates is if you installed the spring discs in wrong. It has been a while since I did mine but it is supposed to like this on each side ) discs ( . Also did you clean and lube the bearing surfaces when you installed back into the housing? Another thing did you make sure to not to mix any of the plates between the two sides? Are you sure it is the actual diff and not the ring and pinion that is the issue?
Old Jan 22, 2016 | 11:19 AM
ReaperX's Avatar
True..... it amazes me how many people prefer the under steer from factory opposed to a proper lsd
Old Jan 22, 2016 | 11:38 AM
nemsin's Avatar
I have been in a 9 after the rear diff plate restacked (to the way the manual actually says they should be mind you) and it made no noise. Nothing like the TRE max lock I drove (which was very noisy). Also, my Evo 6 RS rear diff makes no noise.
Don't give up and settle for understeer.
Old Jan 22, 2016 | 11:48 AM
kaj's Avatar
kaj
subbed in case i can find the pics i took of mine. i think i have them on my laptop.
Old Jan 22, 2016 | 06:00 PM
Ians06's Avatar
More importantly you can get the friction discs to engage on decel instead of accell.... Learned that one the hard way lol. Did you torque everything to spec? Did you install the plates dry? You should like the properly stacked setup MUCH better, unless you don't drive it hard and you would probably never see the benefits. Good luck.
Old Jan 22, 2016 | 06:12 PM
kaj's Avatar
kaj
from factory, in the U.S., it's:
plate, plate, disc, disc, plate-[center of diff]-plate, disc, disc, plate, plate
when it's stacked correctly, it's:
plate, disc, plate, disc, plate-[center of diff]-plate, disc, plate, disc, plate
hope that helps.
Old Jan 23, 2016 | 09:19 AM
spitefire1's Avatar
Okay so I belive I figured it out..the spider gears go in a certain way..meaning cams go into grooves a certain direction..
I belive that the cam has a special direction in the groove..anyone ever experience this?
