Driveshaft carrier stud snapped and don't know how to fix it?
Old Mar 15, 2016 | 11:30 AM
njboy's Avatar
Or.... This is a bit hillbilly but you could saw off the remains of the stud. Drill a hole through the center and tap it if there is enough metal there. Then use a bolt to install the bearing bracket. Fix it OE when you have money.
Old Mar 15, 2016 | 11:56 AM
cts4g63's Avatar
This is how I would do it as long as OE right now is out of the equation.
Old Mar 15, 2016 | 04:55 PM
cficare68's Avatar
URL=http://s765.photobucket.com/user/cficare68/media/Mobile%20Uploads/20160315_170518_zps23oq4i31.jpg.html]Name:  20160315_170518_zps23oq4i31.jpg
I decided to cut an access panel to the top of the stud. The cut the head off the stud and remove the bolt. Just gonna get a new nut and bolt and tack weld the bolt to the car like it was from the factory. Access panel is sealed from the rear so there is no chance of water entering and the access panel is visible being it's under the carpet and on the inside of the driverside seat. Problem solved.
Old Mar 15, 2016 | 08:27 PM
turbobird14's Avatar
grind the weld from the top to remove the stud, then drop in a new bolt and either weld it or have someone hold a wrench on it while you tighten it from below.
This is the route i would go as well.
Old Mar 16, 2016 | 10:55 AM
LetsGetThisDone's Avatar
I would tack weld the "access panel" back in place and seal it with silicone...
Old Mar 17, 2016 | 10:43 AM
cficare68's Avatar
Access panel is sealed from the back so there's not really any chance of moisture getting in there anyways. But I do have some sheets of carbon fiber but I planned on silicone and Sealing to cover the hole anyways. Because you know race car. And as far as the interior goes the car is completely stripped right now anyways you can't even access that location without pulling the carpet and seats to begin with
Old Mar 29, 2016 | 12:20 PM
Evo11274's Avatar
Gonna be a hassle to fix.
Old Jul 6, 2018 | 12:53 AM
cficare68's Avatar
Actually it wasn't. After I cut the access panel dropped a bolt in there and have it tack welded into place. Been two years now and haven't had a single issue with it. Took about an hours worth of time to fix it. Turned out to be a lot easier than originally imagined.
Old Feb 19, 2021 | 11:09 PM
yellowevo82's Avatar
this just happened to me , if I have enough stud left , I'm just going to re thread it. I have a dss cf driveshaft not oem anymore.
ffsman12
May 18, 2015 12:33 PM
sinstr
May 25, 2013 05:17 AM
spooln3
Northwest Region
19
Aug 17, 2011 10:11 AM
AngryEvo8
May 10, 2011 03:42 PM
silver evo8
Aug 2, 2007 01:39 PM
