best evo 8 head components out there?!
Old Mar 17, 2016 | 09:09 AM
matt88davis's Avatar
I have a 03 evo 8 and wanting to start builing the block. Just trying to see what the best parts are for a evo 8 head build. Any help or advice would be great. Thank you
Old Mar 17, 2016 | 09:30 AM
LetsGetThisDone's Avatar
Can't go wrong with GSC and Kiggly.
Old Mar 17, 2016 | 09:46 AM
Also I have 272 cams unsure of what brand.
Old Mar 17, 2016 | 06:12 PM
Teal2nnr's Avatar
Pretty much this.
Old Mar 17, 2016 | 11:28 PM
bwanner's Avatar
dont forget those arp head studs!!
Old Mar 18, 2016 | 05:52 AM
Merle's Avatar
My plan is to go with the Super Tech dual titanium valve springs, GSC S2 or S3 Cams, Keeping the stock lifters as the GSC ones have been known to break and cause bad things to happen and I already have ARP 625 head studs.
Old Mar 18, 2016 | 07:29 AM
Or just buy gsc springs and retainers and call it good. They're about $100 less and proven to be reliable. I haven't heard of a GSC lifter failing, I've also installed them in two 4g63's. They had some issues with a production run of springs once upon a time. But they're all good now..
Old Mar 18, 2016 | 08:01 AM
kikiturbo's Avatar
why dual springs when kiggley and gsc singles work well with those cams?
Old Mar 18, 2016 | 08:08 AM
Merle's Avatar
With regard to the GSC lifters - I read on here and on some FB groups about them being a bit to tall and the heads snapping off. Also was told that STM's RS and RICER ran the OEM ones so I see no reason to fix something that is not broken.
On the springs...down the road I would like to go to a T4 setup and then use the 650 cams and it was recommended to me to use duals if I go that route. So if I go that way it will be to prevent me from having to do the same job twice.
Old Mar 18, 2016 | 08:14 AM
Interesting on the lifters. I would only change if your stock lifters have given out.
On the valve springs, the Kiggly beehives, as well as the GSC's have a little bit higher seat pressure, and similar springs rates to the super tech duals. They would more than handle the STM 650's. And beehives are a much better design than dual straight springs.
Old Mar 18, 2016 | 08:18 AM
Merle's Avatar
Definitely something to consider.
Old Mar 18, 2016 | 11:25 PM
kikiturbo's Avatar
yes, there have been cases of dual springs taking the valve seals off..
Old Mar 19, 2016 | 05:37 AM
ctfpevoVIII's Avatar
Yes its very common, most of the time the wrong diameter seal is used resulting with the inner spring pulling them off.
406EVO
Midwest Region
14
Sep 16, 2013 07:13 AM
evo4g63awd
Dec 11, 2008 05:08 PM
andross85
Northwest Region
19
Nov 14, 2006 03:26 AM
comquat1
Feb 5, 2004 05:06 PM
