Pipe with hole in it
Old Apr 10, 2016 | 03:12 AM
henriklm's Avatar
Hi EvoM.
Last time i posted a thread here i got great response so i though i might as well ask here again, favorite forum btw.
I had a look into my engine compartment and i saw a wire/tube which has a hole in it, i thought that cant be good.
Anyone who knows what this one is for? its located under the BOV close to the turbo.
Thanks a lot in advance.
Br Henrik
Old Apr 10, 2016 | 08:13 AM
Bhsj13's Avatar
is it a hose going to the wastegate? how is your boost?
Old Apr 10, 2016 | 08:19 AM
henriklm's Avatar
Thanks for your reply bhsj13z
My boost is a bit wierd i think, 17-20 psi feels the same, this pipe is 1cm in diameter so its not the wastegate boost pipe but not sure if there is a bigger one from the wastegate.
It just seems wierd that there is a hole that big in the pipe.
Old Apr 10, 2016 | 09:29 AM
RazorLab's Avatar
Photo of what is connected to on both sides would be helpful. That photo above gives me no context.
Old Apr 11, 2016 | 02:43 AM
henriklm's Avatar
Hi Razorlab.
Point taken, its a bit hard to see what its commected too hence the thread, thought it might be a simple answer (one kind of a pipe)
I will try take a few pictures asap, btw is any of the pipes supossed to have a hole in it?
Br Henrik
Old Apr 11, 2016 | 04:58 AM
XSivPSI's Avatar
None should have a hole.
If nothing is leaking out of it, it is likely to be to your wastegate or from your turbo compressor outlet.
Its hard to tell but it looks like the line going from your compressor outlet to the boost solenoid.
blkmkIII
70
Feb 23, 2012 09:01 AM
binh
Sep 3, 2007 07:18 AM
negativeB
Aug 9, 2007 11:13 AM
arnold16890
Lancer Troubleshooting
17
Dec 24, 2004 01:43 AM
arnone_m
15
Sep 30, 2002 10:32 AM
