Dailey Engineering Dry Sump System for the Evo platform now available
Old Jan 3, 2018 | 10:41 PM
  #46
kaj's Avatar
kaj
I've never researched: what's the advantage of a billet block, as opposed to OEM? Weight savings?
Old Jan 7, 2018 | 06:58 AM
  #47
flyingscot's Avatar
I dont know if its an option with the Bullet blocks for the 4g63 but one of the advantages are custom deck heights, the other more obvious ones are better oil paths, better coolant paths, around a 20kg weight saving on the cast block.
I know they require you to run an electric water pump and also they have some good spots for crankcase breathing or regulating vacuum, i would assume the girdle is billet too if they even supply that, i emailed them and heard nothing a while ago
Old Jan 7, 2018 | 02:43 PM
  #48
kaj's Avatar
kaj
Makes sense, if you are going to the "nth" degree. Would be kinda cool to be able to make all the improvements you want. I couldn't imagine ever getting bad *** enough that I find myself needing a billet block (I wish I would, though). Impressive and sure is sexy.
Old Aug 20, 2018 | 08:49 AM
  #49
cpoku's Avatar
Where i can get the revised cam sensor covers so i can put a mechanical pump on the sensor side of the Evo head? I also like this clean look.
Driv200
Jul 10, 2019 06:44 PM
Cameron Barlow
Lancer Engine Tech
Oct 2, 2016 04:17 PM
maperformance
Oct 8, 2013 01:54 PM
maperformance
Oct 8, 2013 11:59 AM
stratis
Feb 25, 2005 05:03 AM
