Can I mix MT90 with MTL??
Old Dec 11, 2016 | 07:38 PM
eddy5201314's Avatar
hi guys, i have a JDM evo 9, I just replace my transmission fluid with 3 quart redline mt90, and I'm getting notchy and grinding shift when car is cold, now can I drain 1Quart of MT90 out and put back 1L MTL fluid in (did some research that's how you fix the notchy and grinding with full mt90 in the transmission)? Car have done about 100km after replace the mt90.
Old Dec 11, 2016 | 08:07 PM
ExViTermini's Avatar
If you read the bottles it says that mixing the two will melt metal.
Old Dec 12, 2016 | 12:58 AM
ok but I read son post in the forum someone mix this two fluid together and notchy is gone, and there's lot of people mixing them together to use?
Old Dec 12, 2016 | 06:16 AM
LetsGetThisDone's Avatar
LOL.
They're fine to mix. Redline also makes an MT75w85 now so you don't have to bother with mixing MTL and MT90.
Old Dec 12, 2016 | 07:34 AM
six40's Avatar
I've ran almost nothing but a MT90/MTL mix in all my DSMs. Mitsubishi transmissions seem to take well to it, yeah you'll be more than good to mix them.
Old Dec 12, 2016 | 01:35 PM
ok thx, so is it fine can I just drain out 1 quart of MT90 and put back 1 quart of MTL back in? Because I don't want to waste the MT90 is already in the transmission.
Old Dec 12, 2016 | 01:37 PM
LOL.
ok, so the MT75w85 = MTL mix MT90?
Old Dec 18, 2016 | 02:20 PM
Bladey's Avatar
Yes that should work fine, idealy you'd buy 2qt's of mt90 and 1qt of MTL.
Old Dec 19, 2016 | 01:41 AM
okay thanks
Old Dec 19, 2016 | 10:14 AM
RazorLab's Avatar
Redline offers MT85 now which is the mix of MT90 and MTL (like people have already mentioned)
Old Dec 20, 2016 | 08:17 PM
does mt85 works great on 6 speed? Because mine is JDM evo9 gsr
Old Dec 23, 2016 | 04:44 PM
WRC-LVR's Avatar
i would use the Diaqueen made for the 6spd. Mitsu recommended. I've been using it for 11 years with no notchy gears on my 05 MR.
Just saying.
Old Dec 24, 2016 | 04:33 AM
Just saying.
thanks I'll give it a try next time because already bought the redline, but stick with diaqueen for t case and rear diff
Graphic
Pacific Northwest
Aug 11, 2012 11:21 AM
Evol.ved
32
Aug 22, 2009 02:29 PM
stryfetew
Sep 19, 2007 12:39 PM
vmrevo9
19
Sep 13, 2007 08:13 PM
Eric Lyublinsky
Sep 6, 2004 10:15 AM
