Manifold question
Old May 6, 2017 | 05:37 PM
oscarquinones's Avatar
Manifold question
How you doing everyone I just need some suggestions. I am currently have a stock frame manifold none ported on my evo ix with a SS JB Black. A friend sold me a tubular manifold the branch is DMe manifold. I never heard about it. I want to change my manifold I feel like is holding me up. I am putting ported intake and throttle this days so I need to know what you guys think if I should put it on or there are not going to crack of something or go with something different.. thanks
Old May 7, 2017 | 12:15 PM
Anyone suggestion.
Old May 7, 2017 | 04:14 PM
Teal2nnr's Avatar
Your intake manifold isn't holding you back. Your money can be better spent elsewhere. Usually about 600whp is when you want to start considering a manifold. If you're really wanted to buy a manifold, look into an AMS or Magnus case mani. I run an AMS as I think the fit and finish is slightly better.
Old May 8, 2017 | 05:57 AM
I am not talking about intake manifold is the exhaust manifold I got a stock frame. Please read above. I know I also say that I am putting a intake and a ported throttle but is the exhaust manifold. I have a friend that give me a DME tubular one but never heard about it that is what I was looking suggestions
Old May 9, 2017 | 06:05 AM
Project_Broke's Avatar
I have one of those manifolds, came on the car. Seems to hold up well, possibly slightly faster spool. It's still a cheaper manifold though. Many seem to go FP, or ported stock manifolds for decent gains.
Old May 9, 2017 | 04:24 PM
Thanks
Old May 9, 2017 | 07:53 PM
Abacus's Avatar
I'd go with an FP Manifold so the cars exhaust note isn't changed and its less likely to crack.
I have an off the shelf one making good power for a few years now. Lots of runs thru it without any issues and looks stock.
The SS JB black should make well north of 600-650whp with a good setup/tuning on ethanol.
Old May 10, 2017 | 11:13 AM
LetsGetThisDone's Avatar
I second the FP manifold. I've installed more than a few of these, very nice piece, much better than stock.
http://www.forcedperformance.net/mer...Lancer-Exhaust
Old May 15, 2017 | 10:00 AM
2006EvoIXer's Avatar
Cause for cracking manifolds?
Does anyone know if the turbo twisting under hard spool up is causing the manifolds to crack? Anyone out there running aftermarket exhaust manifold and O2 housing that retains the bottom bracket? If so, has your manifold cracked? Thanks.
Old May 15, 2017 | 11:20 AM
e_kobz's Avatar
Heat/EGT causes them to crack. An exhaust manifold is going through a non stop heat cycle on a daily basis.
e_kobz's Avatar
OP the FP race manifold is the way to go. I run one on my Evo IX and I love it. Much better than stock or ported stock
Old May 16, 2017 | 01:11 AM
RightSaid fred's Avatar
If you want stock reliability, keep the stock manifold and make an adaptor. Then you can make pretty much any turbo fit, within reason.
As said as above, it's the expansion and contraction from heat cycles that makes them crack.
If they're made extra strong then usually the flanges will warp and leak. Very common on inline 6s like the JZ and RB.
It 's about using the correct materials as well as the correct design.
Cracking has nothing to do with turbo weight and nothing to do with vibration.
DreamerAndy
May 12, 2012 11:47 AM
EvoIXMR
11
Mar 18, 2008 07:31 PM
Carloverx
Feb 5, 2008 04:00 PM
EvlEvo8
Sep 5, 2005 06:39 PM
Bhakuei
Aug 9, 2003 02:46 PM
