WTF am I missing?
Old Jun 5, 2017 | 10:53 AM
  #31
wreckleford's Avatar
Originally Posted by kaj
Yeah, that's what I figured. It felt like popping an IC coupling.. but since they are all still on, I guess it would have had to be fuel cut. The log supports that, from what I can tell, though I'm not sure.
It's not fuel cut. Injector pulse width goes to zero during a fuel cut event.
Old Jun 5, 2017 | 11:21 AM
  #32
kaj's Avatar
kaj
I can 100% guarantee I did not drop a rag into my IC piping, air inlet, etc.
The car did a 3rd gear pull perfectly. On the next pull, I heard the pop and the car lost all power. Got on the gas and it did it again. After that, the pull are without incident but 'Been rich ever since.
Not a rag, but I appreciate the suggestion. It's always the weird, unexplained things that cause problems and we never think of them LOL
Old Jun 5, 2017 | 11:35 AM
  #33
Ok, I misunderstood. I thought the original issue was persisting.
Old Jun 5, 2017 | 11:42 AM
  #34
kaj's Avatar
kaj
Just the running rich part.
Old Jun 5, 2017 | 10:11 PM
  #35
LetsGetThisDone's Avatar
Is it still spooling slow?
If it's running rich, may just need to adjust MAF scaling or the fuel table, or something fueling related (consult your tuner lol). The new MAF may read slightly different than your old one
Old Jun 6, 2017 | 12:26 AM
  #36
kaj's Avatar
kaj
Yes. I found a possible cause. Fixed. We'll see, now. If all is the same, I'm just going to start leaning out the fuel tables.
Old Jun 6, 2017 | 05:48 PM
  #37
4G63_EVO's Avatar
This didnt show up on the BLT
Old Jun 6, 2017 | 07:12 PM
  #38
kaj's Avatar
kaj
Bacon, lettuce, and tomato?
Replaced the coupling. No change.
Old Jun 6, 2017 | 07:20 PM
  #39
4G63_EVO's Avatar
Boost, leak, test.
Damnit, was hoping that would be the gremlin
Old Jun 6, 2017 | 07:30 PM
  #40
kaj's Avatar
kaj
me too LOL. That would be too easy.
​​​​​​Maybe it's leaking from a vacuum line after the TB.
Old Jun 6, 2017 | 07:51 PM
  #41
ExViTermini's Avatar
Have you run a compression test?
Need to simplify it, I spend all day working on cars, it's way too easy to think of something complicated. Engine is air, fuel, compression.
Boost leak test shows nothing, rule that out. Maf readings are same pre and post issue correct?
Keep in mind, air can mean in and out. Do you run a cat on the car? It hasn't come loose and clogged exhaust or something, right?
BTW, sorry these are random rambling's, but are all potential clues/causes.
Old Jun 6, 2017 | 09:06 PM
  #42
kaj's Avatar
kaj
Compression was perfect a week ago; I checked after break in.
I don't have MAF readings from before, but they are normal now.
No cat on the car.
Old Jun 6, 2017 | 09:14 PM
  #43
Checked cam timing?
Old Jun 6, 2017 | 09:48 PM
  #44
kaj's Avatar
kaj
Timing belt jumped? Hmmmm...
Old Jun 9, 2017 | 12:11 AM
  #45
kaj's Avatar
kaj
Update:
viewed logs again. I used to reach 290 load and now I'm in the 305-310 area. Sounds like a boost leak to me, but I've tested at the turbo inlet and the TB. I have yet to find any leaks ANYWHERE. Especially enough to cause a 200-250RPM difference in spool time.
