Borg Warner s200sxe (s257)
Old Sep 29, 2017 | 12:57 PM
  #61
2winscroll's Avatar
No one of those HHR SS's same motor tho.
Old Sep 29, 2017 | 01:05 PM
  #62
Eric SlowEvo8's Avatar
oh true forgot to meantion that one the LNF platform I had the older LSJ sc and went turbo with it
Old Sep 30, 2017 | 09:28 AM
  #63
RWD4G63's Avatar
Originally Posted by 2winscroll
All this experience and no pics, graphs, or proof of any kind. Where are these manifolds? Dyno graphs? Do you work for Extreme Tuners?
Borg Warner made these housings with smaller T3 volutes for a reason. If you want to gain several hundred RPM in spool use a small tube header combined with the properly sized exhaust housing. If you want to bandaid fix use a T4 header with a smaller a/r.
So heat is 70% of why a turbo spools eh? Wrong! Heat creates expansion which in turn causes gases To move at higher velocities. Air movement through the turbine is the only reason a turbo works period.
You must know more than ford engineers because they are squeezing a 3.5l engine exhaust through two holes that are 1.15" diameter and getting 400hp out of that. Zero spool time.
Header tube size matters no matter how you twist it around in your favor. Small tube header vs. big tube header same a/r, the small tube will always outspool the big tube period. So your wrong there too.
I don't need to post all that **** when the information is all over the internet. A simple google search will turn up plenty of articles and white papers that support what I'm saying.
400bhp out of a 3.5liter is not impressive. They simply use small turbos to make the engine seem larger and be more efficient. Is it really that hard to wrap your brain around? We're not talking about OEM philosophies here, we're talking about performance applications, where less compromise is present or necessary.
I will say this one more time. You can build a small runner divided T4 manifold. I already agreed with you on runner size...
T4 Divided is the way to go. Period. Another fact that supports me here is that the EFR line is all T4 divided, including the small B1 frames.
Originally Posted by Strm Trpr
The S259 is a 59mm billet inducer from Bullseye, if I'm not mistaken.
I would imagine the new tech of the SXE should match or best that in the same housing, hence why I'd run the 1.22 A/R T4 flanged housing and have the T3 inlet gasket matched like shown above.
What size pipe and design manifold, i.e., bottom or top mount, was on the VR4?
RWD4G63, may I PM you to discuss your experience with these turbos and DSM's?
This was the cast wheel S259, old tech. Manifold was a sch10 longrunner forward facing unit. If you're going to run it on a 2.0 liter, I'd suggest stepping down to a 1.15 or 1.00, unless of course you're going to push the turbo really hard. Feel free to PM me.
Old Sep 30, 2017 | 09:38 AM
  #64
RWD4G63's Avatar
Old Oct 1, 2017 | 02:16 AM
  #65
2winscroll's Avatar
any off the shelf T4 will be a large runner manifold BTW. That's what I'm trying to say the smaller runner T3 manifold with net you quicker spool.
Old Oct 1, 2017 | 02:19 AM
  #66
2winscroll's Avatar
Your missing the point.
Old Dec 31, 2017 | 04:50 PM
  #67
SnailSpeed's Avatar
Happy new years eve haha, sorry for the bump but has anyone managed to use the s257sxe? been considering this turbo myself.
Old Jan 2, 2018 | 08:11 AM
  #68
LetsGetThisDone's Avatar
I was considering, but the inducer is too big for some of the class I would like to run for Time attack stuff I would like to do in the future.
Old Jan 6, 2018 | 06:29 AM
  #69
RWD4G63's Avatar
Friend of mine at WSRD.
There is a 52mm version.
Nice edit.
Old Jan 9, 2018 | 01:35 PM
  #70
SnailSpeed's Avatar
Nice edit.
Any more info on this car? power figures?
Old Jan 9, 2018 | 02:49 PM
  #71
It doesn't flow enough, only 55lb/min.
Old Jan 10, 2018 | 11:30 PM
  #72
cficare68's Avatar
I just recently purchased the s257 sx-e w/ an AGP t3 .82 ar turbine housing. I have an aluminum rod 2.4 w/ kelford 276 high lift cams.
Old Jan 11, 2018 | 05:31 PM
  #73
Strm Trpr's Avatar
Excellent cam choice for the heavy breathing 2.4L!
Any head work?
Upgraded springs are a must with the HL276's, which did you go with?
What are your goals and other planned mods?
How long until we get some results out of your build?
Old Jan 11, 2018 | 11:19 PM
  #74
cficare68's Avatar
Any head work?
Kiggly high pressure springs. Been running them in the head for 5 years now. Heads been every since the car was stock block.
Actually went this route to make the car more streetable (previous turbo was a gen 2 6466) looking for around 450 to 500 on this setup. Big power cars are fun but you loose all the daily drivability with them and I enjoy driving my car. So I decided to try this turbo out and build an auto dsm for big power.
Car has been downgraded quite a bit from its previous setup. I'm reusing my forward facing stm t3 manifold and using a non cdi ignition and fic 1250cc injectors this time around and keeping my 450 double pumper w/8an feed and 6an return fuel lines and its tune on AEM V1. Car has an exedy triple w/ a buschur built ultimate ratio trans w/ 4.11 final drive in it.
I do expect mine to spool a little later than most setups cause I have a jm fab drag intake manifold on it. I know back when I was on a 3076r it made the turbo spool a little slower but the turbo seemed to breathe a lot better up top.
I ordered pretty much everything I need to get it running last night so its more of a waiting game. From there it really depends on the weather for tuning since my car is street tuned.
Old Jan 12, 2018 | 09:11 AM
  #75
Strm Trpr's Avatar
Damn that's awesome, I can't wait to hear about your build!
Please keep us posted!
I have a 99 GSX I'm building for road racing track days and street sweeping...
I have a virgin 99 4G63 and a virgin 99 4G64 I can build.
I can't decide which to build, a LR2.4L or a 94mm destroker....
