Normal driving and one cylinder shuts off and cames back randomly???
Old Oct 2, 2017 | 04:40 PM
RightSaid fred's Avatar
insulation breakdown would change the impedance of the coil..... once again your gonna claim that the engineers who made this stuff dont know what they are doing but you have the right answers.
Still wrong.
That's why it's called "Insulation breakdown".
So you've got even less of an idea than no idea at all.
Yes the Mitsubishi engineers got it right with the wasted spark and COP is a downgrade.
Old Oct 2, 2017 | 04:43 PM
Biggiesacks's Avatar
its like following a jackass around and cleaning up the piles of **** coming out the back. Im checking out of pooper scooper duty on this one.
Old Oct 2, 2017 | 04:44 PM
which is why mitsubishi put cop on the 4b11t right?
Old Oct 2, 2017 | 05:06 PM
"Impedance"is an AC measurement associated with a running coil. It changes with frequency.
A multimeter can't measure impedance, only resistance, voltage, current etc.
Old Oct 2, 2017 | 05:12 PM
"Impedance extends the concept of resistance to AC circuits, and possesses both magnitude and phase, unlike resistance, which has only magnitude. When a circuit is driven with direct current (DC), there is no distinction between impedance and resistance; the latter can be thought of as impedance with zero phase angle."
https://en.wikipedia.org/wiki/Electrical_impedance
jesus why do i keep shoveling this bull****...
Old Dec 13, 2017 | 06:30 AM
audiofan's Avatar
Solved the problem, It was a faulty Cam sensor
Got a used sensor from a junkyard, and it worked perfectly for around two weeks, now it is starting to do it again, same problem.
What could be making the cam sensor go bad?
Old Dec 13, 2017 | 08:09 AM
LetsGetThisDone's Avatar
What exhaust manifold do you have?
If its a tubular manifold, do you have a heat shield over the sensor?
Have you tried a new OEM sensor?
Old Dec 13, 2017 | 10:28 AM
audiofan's Avatar
toxicfab tubular manifold , it does have the cam sensor heat shield
I will try a new sensor
Old Dec 14, 2017 | 09:26 AM
BobbyB13's Avatar
I'm presently struggling with a misfire / cylinder shut-down as well, (link below)... How / why did you come to the conclusion it is your cam sensor? Do you have a diagnostic code or trial and error? If the problem is still coming and going since you replaced that sensor that might not be your problem... Have you done a compression test?
https://www.evolutionm.net/forums/ev...agnostics.html
djlonewulf
May 15, 2013 09:03 AM
jimmy_james
Lancer Troubleshooting
Apr 6, 2010 08:37 PM
SRT4 to Evox
13
Apr 8, 2009 12:02 PM
95lsvtec
Nov 16, 2008 09:31 AM
evolutionninemr
Jun 6, 2008 06:08 PM
