Injector Dynamics ID1050x vs 1000
Old Dec 11, 2017 | 09:16 AM
Boost411's Avatar
Good day,
Can you advise on which injectors would be better and whats the difference between them. Thinking about installing a set on my evolution 5 but not sure which to get.
Old Dec 11, 2017 | 09:19 AM
LetsGetThisDone's Avatar
The 1050 just flows a little more fuel. Can probably eek ~480whp out of them with a high flow fuel pump like a walbro 450. The 1000's will be done before 450whp. Those numbers are for E85.
Old Dec 11, 2017 | 11:23 AM
Dakota Evo's Avatar
i think the new id will take oxiginated fuels such as q16
check and verify this also wont corode as much as the fic1100 or id1000
ive changed 2 sets of fic2150 because ive left the car sitting with ethanol for a month
Old Dec 11, 2017 | 12:05 PM
heel2toe's Avatar
^Ethanol or methanol? I thought most if not all injectors these days are ethanol safe, no? Thats a lil concerning if thats not the case...
Old Dec 11, 2017 | 12:09 PM
No, the 2000's can corrode with Ethanol. A month is pretty fast though.
Old Dec 11, 2017 | 12:19 PM
heel2toe's Avatar
Ugh are you serious? That's no bueno...
Guess I dont like the 2150's anymore then. Looks like Im after the new FIC1200's which are actually different than the 1100's as it turns out, ID1300's which are $$ or the FIC1650s which are also $$
Old Dec 11, 2017 | 12:24 PM
FIC doesn't say anything about the 1200's being stainless..
Old Dec 11, 2017 | 12:32 PM
heel2toe's Avatar
Hmmm thats a good point. You suck Im going to have to get the more expensive ones aren't I?
Although FWIW my PTE1000s were fine all these years. But the car rarely sat so...
Old Dec 11, 2017 | 01:51 PM
Also just noticed ID no longer list the 1000's on the site.
Old Dec 11, 2017 | 02:47 PM
e_kobz's Avatar
I’m friends with the owner of ID and a few of the people who work there. I can tell you that the 1000’s and the 1050x’s will flow exactly the same. Only difference is the internals and the 1050x’s have a different spark pattern which is supposed to help with low duty cycle’s. The 1050x is replacing the ID725, 850, and 1000. The goal with then 1050x was to replace all three of those injector sizes
Old Dec 11, 2017 | 03:27 PM
If it flows the same, why do they say it's bigger? lol
Old Dec 11, 2017 | 04:16 PM
e_kobz's Avatar
Didn’t bother asking
Old Dec 11, 2017 | 09:47 PM
4b11slayer's Avatar
I ran my fic 1450 blue max on e85 for 2 years and pulled them for head job. Feed port was clean but port that goes in manifold was supppper gunked up. Not sure if its cause e85 or what. But the gunk was thick and gum like.
Old Dec 12, 2017 | 04:25 AM
Boost411's Avatar
Thanks guys. Will go with the 1050x then.
Old Dec 12, 2017 | 07:59 AM
On the website it says they flow more, and on the fuel flow calculator on the website, it says they flow more. How much does your guys at ID know? lol
