Lean AFR at Idle
Old Mar 25, 2018 | 11:48 PM
  #31
RightSaid fred's Avatar
It's broken.
Originally Posted by sowne
It's installed before the cat, I have "Mistubishi Outlander Turbo"(And rear O2 sensor is before the Cat), .
Rear o2 sensor is after the cat, not before it and as such, it's the wrong place and it'll read lean.
Unless you've mounted it somewhere different and you're tripping.
So it's what I said it was a few months ago.
​​​​​​​Ideally you should be data logging the NB o2 sensor.
Old Mar 26, 2018 | 01:00 AM
  #32
sowne's Avatar
Originally Posted by RightSaid fred
It's broken.
What do you mean is broken?
Outlander Turbo has 2 cats, one between front and rear O2 sensors, right after uppipe, second one after second O2 sensor. Front cat got removed when I installed EVO aftermarket downpipe, second one got replaced with 3" one. So now there is front o2, wideband sensor, second o2, highflow cat. in that order
Old Mar 26, 2018 | 07:24 AM
  #33
2006EvoIXer's Avatar
I didn't know you have an Outlander. That explains the misunderstanding. Make sure your UEGO isn't too close to cat because readings will be skewed from cat slowing the flows down and you getting a more blended reading of extra cylinders (it is already blended enough because of the turbo).
​​​​​​Does your spark plugs have white residue?
Old Mar 26, 2018 | 08:16 AM
  #34
sowne's Avatar
UEGO is around 20cm before cat(that would be 7-8inch I think), don't know about spark plugs but, turbo hot side look really clean and white. Also cylinders the same way when looked via scopecam.
Old Apr 23, 2018 | 01:00 AM
  #35
sowne's Avatar
I was reviewing my ROM today and noticed that idle ignition timing is advanced, it's aroud 10* instead of 5*, also idle timing compensation limt is set 3 instead of 8. I guess those changes were to make idle more stable.
Could it be the cause of lean idle? if yes, how can I fix it or should I leave it like it is?
Old Apr 23, 2018 | 02:27 AM
  #36
Evo VI.'s Avatar
Lower idle rpm requires higher timing to prevent stalling.
what idle RPM are you running with those cams?
Old Apr 23, 2018 | 02:58 AM
  #37
sowne's Avatar
950,
And I had to reduce overlap(smth like, -4,+2) a lot to make it stable, I really surprised why S1-s require such effort, I wonder how people with really aggressive cams handle it.
Old Apr 27, 2018 | 09:10 PM
  #38
inin36's Avatar
Same
Its normal. Im having the same reading as u. Tuner also said due to the cams.
jtbell86
11
Aug 1, 2020 09:23 PM
sound77
May 13, 2012 06:53 AM
Nissan2Evo
AEM EMS
Feb 4, 2009 10:15 AM
sharkm87
Nov 15, 2008 03:59 AM
