View Poll Results: 2.1/2.2L Rod Length
Voters: 10. You may not vote on this poll
2.1L Stroker 4G63 Evo 8
Hi all,
Looking at building a 2.1L/2.2L stroker engine for my Evo 8.
4G63 Block and 94mm stroke crankshaft
I've read multiple threads and found that you can use either 150mm, 153mm or 156mm rods.
What would you choose and why? Does anyone know the Pros & Cons of each?
Originally Posted by nathantk94
Hi all,
I've read multiple threads and found that you use either 150mm, 153mm or 156mm rods.
I've read about others that run the 156mm long rods on 94mm and claimed to have no problems revving to 9000 RPM. But my calculations don't agree. If you want a race car where you are refreshing the engine often, then this could work well.
How do you plan to use this motor? Daily or track? How often do you plan to refresh motor? How much power do you plan on making for regular driving and how much for all out races? Tranny build and gears?
Thanks for the reply. Mostly street and occasional track work. Looking support around 600-700hp at the wheels.
Not planning to refresh the motor, so I would like it to be as reliable as possible.
I'm leaning towards 150mm as 153mm seems quite hard to source.
153mm Rods and appropriate pistons can easily be sourced from English Racing.
Building a 600-700whp four cylinder and "not planning to refresh it" don't exactly go hand in hand.
There's no set interval. But when you're making 150-200hp/cylinder, stuff doesn't go 100k miles.
Refreshing interval is based on how much power you're running your engine and how often. If constantly running on street/freeway in kill mode (700whp) I wouldn't wait to refresh more than every 30k miles. If running on street/freeway in mild mode (600whp) and not always getting on it until track days on occasion in kill mode, I'd probably refresh every 50k. The trick is to refresh to catch anything going offspec before engine fails. Bearings are cheap. Gaskets can add up. But failure could cost as much as a new build. You gotta pay to play!
Carillo rods and Wiseco pistons from English Racing.
marc_pogson
Jun 5, 2023 04:36 PM
JSC Speed
Feb 21, 2008 08:10 AM
JSC Speed
Evo 'For Sale' Engine Internals and Drivetrain
Jan 22, 2008 01:31 PM
JSC Speed
Jan 11, 2007 09:02 AM
