Need help diagnosing a loud tick in engine - Video link.
Old Jul 16, 2019 | 05:56 AM
overdrive1's Avatar
Hi all,
Need help diagnosing this noise. Engine has 109,000 miles. A lifter maybe ? Compression tested and between 170 and 180 across all 4 cylinders, so no issues there.
- Accessory belt is off. Sound is definitely from the engine
- Crankshaft inspected - no wear at all, rod bearings replaced.
- Lifters replaced.
- Turbo was blown and it looks like it sent some bits into the engine, I found some aluminum bits/dust in the oil pan.
Dont know the backstory on the car, I bought it with the noise.
Old Jul 16, 2019 | 06:53 AM
Yeah, certainly does not sound right. Stock cams & springs?
One of those mechanics stethoscopes may help in pinpoint that tick?
Old Jul 16, 2019 | 07:05 AM
overdrive1's Avatar
Dont know the history of the motor. Just picked it up as is with the noise and all. Sounds like lifters but very loud.
Old Jul 17, 2019 | 07:48 PM
overdrive1's Avatar
accessory belt removed and no change in noise.
Old Jul 21, 2019 | 02:56 AM
2006EvoIXer's Avatar
When it's that loud, I'd grab a mechanic's stethoscope and listen on the block for rod knock. Does the noise increase in frequency as you rev higher?
Old Jul 21, 2019 | 05:47 AM
overdrive1's Avatar
Thanks, that's what I'm leaning toward. Yes the noise increases in frequency as I rev higher. I'll probably just swap in a new block.
Old Sep 22, 2019 | 08:02 PM
overdrive1's Avatar
- Lifters replaced.
Not sure what else to do.
Old Sep 23, 2019 | 06:04 AM
240Z TwinTurbo's Avatar
Timing belt tensioner probably has play
Old Sep 23, 2019 | 11:10 AM
Do you have pictures of crank and rods?
Old Sep 23, 2019 | 11:30 AM
overdrive1's Avatar
Should've got pics but I didn't unfortunately.
Old Sep 23, 2019 | 12:21 PM
Can you post up pics of your old rod bearings?
Old Sep 23, 2019 | 02:29 PM
overdrive1's Avatar
Pics attached
Old Sep 24, 2019 | 05:58 AM
Icecruncher's Avatar
My mom's V6 2014 Mustang has had a quieter version of this for years now. Even a few Ford dealers had no luck. Yours sounds more like a bolt is loose and my mom's more like a cam or something.
Dragon123
Oct 1, 2016 03:04 PM
maknuge
39
Dec 6, 2013 10:09 AM
adamgetem
14
Apr 4, 2011 09:37 PM
Master Evo8
10
Oct 23, 2009 10:09 PM
Mattsilverevo
15
Apr 25, 2008 07:19 PM
