another ticking noise thread (with video)
Maybe nothing to worry too much about? Cold start lifter noise? How about using that stethoscope to pinpoint?
What cams, springs & lifters are you running?
running stock fq360 cams, stock springs and stock lifters
Sounds like something is loose and engine vibration is causing it to hit something else.
But since your valve cover is already unbolted, with the engine off, press on each rocker to see if any budges. They should all be solid stiff.
My VI does the same on start up and once it’s up to normal running temperature, it goes away. So I’m also wondering the issue. I still have stock engine. I was also told it could possibly be lifters from a mechanic and shouldn’t be a problem. I’m sure someone here is more knowledgeable though
Maybe timing belt tensioner. On wife’s Odyssey it would clack at startup and go away, but sounded like lifters. When removed it was still sealed, but had play. Replaced and problem solved. Same issue on my EVO IX that I swore was a bad MIVEC gear as it also made a clacking sound. In this case the tensioner had oozed out the grease and had significant play. Any play in the tensioner will cause belt slap sounding like the lifter noise.
skans789
Oct 16, 2009 02:49 AM
