Crankshaft
Old Jan 7, 2020 | 11:19 AM
EDDIEGSX's Avatar
Crankshaft
What do you guys recommend for a 1000 hp build crankshaft was looking into a stock stroke 4g63 billet callies crankshaft I heard manly ones crack. Any recommendations would be appreciated.thank you
Old Jan 7, 2020 | 12:12 PM
2006EvoIXer's Avatar
Good luck, there was a lot of discussions on billet Manley cranks. Do a search and find them all. I think Callies are made from same cores but they machine here much better.
Old Jan 7, 2020 | 12:14 PM
Personally, I will stay away from oil ports drill at an angle.
Old Jan 7, 2020 | 01:00 PM
EDDIEGSX's Avatar
[QUOTE=2006EvoIXer;11897163]Good luck, there was a lot of discussions on billet Manley cranks. Do a search and find them all. I think Callies are made from same cores but they machine here much better.
Old Jan 7, 2020 | 01:02 PM
EDDIEGSX's Avatar
OK I guess OEM is the best option
Old Jan 7, 2020 | 01:09 PM
I think OEM cracks the most. But these cracks are at the corner whereas the Manley Billets crack from the #4 rod oil ports. So I'm not sure what the best option is. Lol
Old Jan 7, 2020 | 01:31 PM
EDDIEGSX's Avatar
What about K one or eagle kind of heard some good stuff about that company.
Old Jan 7, 2020 | 02:44 PM
LetsGetThisDone's Avatar
For 4 digit power, you're going to want an 88mm stroke. English Racing uses the Eagle forged crank in their 1400whp Drag Evo 8. I'd go that route.
Just keep in mind, nothing is "bullet proof" in 1000hp 4 cylinder.
Old Jan 7, 2020 | 04:12 PM
CurseDSM's Avatar
I am using a stock 64 crank. It should hold up to the power as long as I don't over rev.
Old Jan 7, 2020 | 06:40 PM
hutch959's Avatar
do whatever english does... or get them to build it.
Old Jan 8, 2020 | 01:37 AM
CurseDSM's Avatar
I would agree with this but like in my case there are things shops will not tell you. Over reving is the main killer with the 4g64 cranks being they arent designed to be high reved hince they crack. The cranks have a natural wabble to them reguardless of how well they are balanced. I have been told this buy a guy who makes crankshafts at a place called moldex crankshafts here in Michigan.
Old Jan 8, 2020 | 04:08 AM
ConEvo's Avatar
Recenlty from what I see and hear, Callies is the most used crank for high horsepower builds. Manley had some issues especially with the 4th journal but I do not know if they solved it. Also it should be noted that it is reasonable to see more failures than others because it was the most sold crank in contrast with other brands. The last few years Evo owners changed what we actually consider high horsepower engines and went from (800-1000whp) to 1000-1400whp
Old Jan 8, 2020 | 07:52 AM
Over rev is not the "main" killer. The reality is all the cranks end up cracking at 900-1000whp+ level (Yes, even Winberg) it's just which one lasts longer. Imagine the surprise, ER run's an Eagle forged over a Winberg or something other billet option. It's what they've found to have the best reliability.
As one of the few shops running 7's in a CT9a, and almost in the 7's with the X's I think ER has a bit more clout than the average...
Old Jan 8, 2020 | 01:43 PM
CurseDSM's Avatar
I agree 100%
roni4g63
Oct 28, 2016 01:43 AM
Tyler.willis92
32
Oct 9, 2014 11:19 AM
Gramdollar
Oct 24, 2011 07:42 PM
SloEvo12
35
Oct 20, 2010 08:21 PM
Meevo
12
Dec 6, 2008 08:48 AM
