cant find this boost leak
Old Jan 12, 2020 | 09:48 AM
PalmTreeZ's Avatar
Hello guys, so ive had about a 3-4 pound boost leak, ive tried a boost leak test with my friend but we heard nothing, ive checked all hoses and all the routing, everything's connected, i replaced my throttle body seals, both of them, erg hose that popped off was also put back on, replaced some older boost lines and just checked all the intercooler piping and replaced the hoses for those aswell and tightly secured all clams, even put a new intercooler in just incase, atlas still a boost leak, so i replaced my boost sensor and gauge thinking it was that but still the same, at this point im thrown for a loop, my dad said it might be the waste gate stuck slightly open, can this happen ?
Old Jan 12, 2020 | 10:28 AM
LetsGetThisDone's Avatar
What do you mean by a "3-4lb boost leak"? When doing a boost leak test the system always leaks down as air goes through the engine.
Old Jan 12, 2020 | 11:08 AM
PalmTreeZ's Avatar
just looking at my boost gauge before it was 20 under full boost now its 14-16 at most
Old Jan 12, 2020 | 11:41 AM
That's probably not a boost leak. More likely a turbo or waste gate issue.
Old Jan 12, 2020 | 04:26 PM
hutch959's Avatar
or some bad gas... and the thing is knocking and its trying to limit boost.
Old Jan 12, 2020 | 04:46 PM
RazorLab's Avatar
That's not how it works.
Old Jan 12, 2020 | 04:58 PM
The stock ECU can reduce wgdc on knock if running a Tephra rom. But I've never seen anyone use that feature. And it wouldn't constantly be 4psi low.
Old Jan 12, 2020 | 05:18 PM
RazorLab's Avatar
Right, on the 10 you can reduce it via TPS. I assumed the OP would also say the car was blaring the knock CEL light as well.
This has text book wastegate pressure/issue written all over it.
Old Jan 12, 2020 | 05:37 PM
I agree
Old Jan 13, 2020 | 03:16 PM
PalmTreeZ's Avatar
Would this cause a check engine light to come on if it was knocking for 5 months? Also i did a compression test and all cylinders are 180-190
Old Jan 13, 2020 | 03:18 PM
RazorLab's Avatar
Check boost control hoses/connects, check wastegate actuator and actual wastegate flapper.
Evolicious8
Aug 18, 2012 11:20 PM
Carter19
11
Apr 30, 2010 08:32 PM
vegasevo9
Feb 15, 2008 11:07 AM
TKEVO
23
Aug 25, 2007 12:23 AM
joedr
Mar 9, 2006 10:51 AM
