Gears dont go in when car its on
Old Apr 3, 2020 | 12:10 AM
evoholic3088's Avatar
Hey all,
so back again with more problems. Had a dead clutch pedal, changed slave and master clutch cylinder. Bled the system, clutch was good. Gears go in smoothly when car is off but once car its on gears wont go in. If i start the car in gear it jerks at first but does move and while moving i can shift gears. Once stop then gears wont go in. I just toke down the transmission thinking it was the TOB or clutch but TOB looks 'okay' and clutch looks pretty good. Flywheel bit burnt but everything looks normal dont know what else check. Any other suggestions to check or what it could be?
Old Apr 3, 2020 | 10:01 AM
colo_evo's Avatar
Clutch isnt disengaging. Need to figure out why.
Old Apr 3, 2020 | 10:08 AM
motempest's Avatar
Have you adjusted your clutch pedal? Could be that its not far enough for it to disengage.
https://www.evomoto.com/tech_article..._article_id=28
Old Apr 3, 2020 | 04:45 PM
hutch959's Avatar
go to jacks transmission web site and watch video on how to adjust clutch.
if that doesnt do it, pull the tranny and see what the problem is.
Old Apr 3, 2020 | 11:20 PM
Thank you for help/tips guys,
But I was thinking same thing i did adjust the pedal few times all the way in and all the way out and in between but it was just same thing.
transmission its down, clutch looks good, flywheel bit burnt but good.
i was thinking my fork maybe has a crack or something and when i step on clutch fork just bends so its not making its job but looks okay. What i did notices one leg of the fork comes out the TOB when i pull it all the way back.
Old Apr 4, 2020 | 04:52 PM
hutch959's Avatar
sounds like you found the issue.
i would replace TOB and inspect fork real good.
i dont think the forks typically break.
elhuberto
21
Dec 1, 2011 09:39 PM
kvinh90
Jul 24, 2011 12:35 AM
RREvoxGSR
29
Mar 10, 2010 07:23 PM
03blkevo
16
Aug 16, 2009 09:04 AM
kylepaschke
Lancer Tranny/Drivetrain Tech
14
Dec 14, 2007 12:03 PM
