Help! Evo is making loud while while turning
Old Apr 14, 2004 | 12:06 AM
John4321's Avatar
Help! Evo is making loud whine while turning
Ok my car has 4000 miles on it and I just had the following installed:
HKS 272/272
APS DP & Catless midsection
Greddy Titanium Catback
Super AFC2
Hallman Boost controler
Defi Boost gauge
HKS turbo timer
Bushur Intake
Bushur Intake pipe
After driving it around for a while I noticed a very loud whine anytime I turn the wheel slightly. I already checked my fluid and it is fine. The car has never been to the track and has only seen 4 launches from a stop.
Is there anything while installing these parts that could cause this noise to occur? Anybody else have this same problem? I did a search and came up with very little. Any imput would be greatly appreciated. Thanks, John
Old Apr 14, 2004 | 07:13 AM
evo 8 ya's Avatar
You said you check your fluid??? What fluid are you talking about. If you checked you P/S fluid and it's full... It might be the transfer case. good luck
Old Apr 14, 2004 | 08:26 AM
John4321's Avatar
yes p/s is what I checked. Is the whine while only turning an indication that transfer case could be going bad?
Old Apr 14, 2004 | 10:26 AM
John4321's Avatar
ok I double checked the p/s fluid this morning and added some fluid which it took so I guess it was a little low. I tell you what though, I didn't sleep at all last night I was so worried about this. Thank God thats all it was. John
Old Apr 14, 2004 | 12:15 PM
Space Monkey's Avatar
That sounds like a powersteering pump going bad. How many miles do you have on the car?
Old Apr 14, 2004 | 03:39 PM
John4321's Avatar
4000 miles, but all is good now. I guess when they were putting in the cams they removed a hose from the p/s fluid tank
and some did leak out, they just thought it wasn't enough to make a difference.
sc_s13
11
Aug 3, 2010 11:38 AM
Pure Playaer
Jan 21, 2008 03:17 PM
TurboSaleen#163
14
Sep 14, 2005 08:49 AM
1mbrews8
Jan 6, 2005 07:48 PM
jstaats26
11
Mar 31, 2004 01:48 PM
