2.3l fp black fueling questions.
Old Jun 1, 2020 | 04:18 PM
DSMolition's Avatar
So I put a rod through my stock block with a red after driving it at 450hp for a few years. Looks like a Piston cracked and went through the pan.
​​​I'm rebuilding and orderd a oem 2.3l build from map weisco 1400hd, turbo tuff rods and stock 100mm crank. Arp everything and all that they offer.
​ I am also having my red rebuilt to a black as it took a chunk of piston through the turbine.
​​​​I'm building a doubble pumper using my dw 320lph pump for the primary and a Wally 255 that I have sitting around for the secondary. The secondary will run on a Hobbs switch. Will be used with 2150cc
MY question is I have two -6 running from the pumps going to a y. For the other end of the y Do I need to run a -8 to the rale or would I be ok with my existing -6 in the car? I'd rather not have to get a different fuel lab filter and fuel rail fittings for - 8 unless I need to.
Goal is around 600/650 e85 of course.
Old Jun 1, 2020 | 04:24 PM
240Z TwinTurbo's Avatar
GTR guys run factory -6 line north of 1000whp.
Old Jun 1, 2020 | 04:27 PM
ronaldo9's Avatar
That's plenty for fuel. People make that power on stock lines. Good luck with the build.
Old Jun 1, 2020 | 04:34 PM
DSMolition's Avatar
Right on. I was told that I would out run a single 450 pump at around 600 on the mustang Dyno I will be using, Only reason I'm doing doubble pumps to have plenty of fuel
Old Jun 1, 2020 | 04:35 PM
LetsGetThisDone's Avatar
As has been said many times on this forum- Do not order an engine from MAP. There are many other places to get a properly built engine. MAP isn't one of them.
Also, building a 2.2L/94mm crank motor is much preferred over a 100mm motor.
As single walbro 525 with hi/lo voltage rewire (and siphon drilled to 9/64"), upgraded fuel rail, mostly stock lines (replace the underhood portion of the feed line with the STM -6 kit to get rid of the restriction at the fuel rail inlet), and 2000cc injectors would be plenty of fuel.
Midnightevo8
194
Aug 11, 2018 12:14 PM
s36577p
Feb 23, 2017 12:48 PM
dw cuz
Sep 23, 2014 07:07 AM
iceman23007
Feb 5, 2013 03:11 AM
parido
37
Nov 3, 2010 07:40 AM
