Clutch issue
Old Sep 2, 2020 | 09:03 AM
RussianEVO's Avatar
Clutch issue
Car is a 2003 evo 8 with 180k miles, I daily drive it. About 20k miles ago I had the clutch replaced with a stock Mitsubishi flywheel and ACT hdss street clutch kit. Car got tuned at KTmotoring and is making 290hp (good enough for me for daily).
Clutch grabs towards the top, but sometimes changes position depending on what gear I am in? Also latley it has been locking me out when I try to down shift, like when I have the clutch pedal pressed in the RPM’s don’t drop, if I hold it down it takes like 3-4 seconds for the RPM’s to fully drop to where I don’t get locked out and I am able to change gears.
ps. Sorry for the bad explanation, I’m horrible at explaining lol.
Thanks for looking,
Kyle
Old Sep 2, 2020 | 10:18 AM
LetsGetThisDone's Avatar
Did you try adjusting the pedal?
Old Sep 2, 2020 | 11:51 AM
RussianEVO's Avatar
I did when I got the new clutch installed, haven’t since, I thought these were self adjusting from the slave? In order to fix this should I try clockwise or counter clockwise?
Old Sep 2, 2020 | 12:37 PM
theres a mechanical adjustment on the pedal. You want about an inch of free play at the top of the pedal.
Old Sep 2, 2020 | 12:43 PM
RussianEVO's Avatar
Okay thank you so much! I’ll go ahead and try that now
Old Sep 2, 2020 | 07:01 PM
RussianEVO's Avatar
Problem still persists sometimes now, although gears 1-2 got way better! They are smooth as butter now. It happens only when trying to down shift gears 4-3. Its almost like the gear doesn’t want to come out so I have to put a little more force into it to take it out.
Old Sep 3, 2020 | 07:55 AM
RussianEVO's Avatar
Okay so, my pedal got way softer, almost like “squishy” ? And it did it again in 2nd at a stop light, taking it out of gear seems to be the problem I also noticed it happens when the idle RPM’s are lower then the idle RPM’s. I think I’ll try replacing the master cylinder and slave cylinder and bleeding the system.
Old Sep 3, 2020 | 08:52 AM
Look up in the bell housing through the access hole on the bottom. Try to see if the throw out bearing is falling apart.
Old Sep 3, 2020 | 10:06 AM
RussianEVO's Avatar
will do! Also I found other people who basically have the same issue as mine also, seen here https://www.evolutionm.net/forums/ev...tuck-gear.html They have not found the issue ether witch sucks. His is happening when he’s at high RPM though.. so idk -_-
Old Sep 17, 2020 | 09:58 AM
RussianEVO's Avatar
Found the issue, my clutch was bad, it was the old “style” ACT with that janky chinese/plastic ring in the middle of pressure plate along with the throw out bearing. It was causing it to get stuck together sometimes on decel. Weird but just ordered a new clutch from act with that “all metal ring” I guess they updated their clutch a bit.
thadon84
38
Aug 23, 2016 12:35 PM
stryfetew
Feb 13, 2009 01:06 PM
red12x
Dec 11, 2008 12:37 PM
Travisivart190
Aug 10, 2007 06:51 AM
Assassin
10
Dec 3, 2005 05:57 PM
