In gear when neutral
Old Oct 17, 2020 | 04:12 PM
Stefano Calonge's Avatar
I have a 2006 evolution 9 mr with a 5 speed swap it has a exedy twin disk. When the car is in neutral I let go of the clutch and it stalls out like as if it's in gear. When I go to reverse the car moves but only about 2ft then gets stuck like it hit a log in the road.. Anyone have any ideas what can be the issue?
Old Oct 17, 2020 | 04:22 PM
hutch959's Avatar
when the motor is not running does it seem like it shifts through the gears ok?
i would check your shift linkage and make sure everything is correct.
Old Oct 17, 2020 | 04:26 PM
when the car is on and yeah it shifts fine throughout the gears just when I put in neutral stalls out like it's in gear and goes into reverse but doesn't move
Old Oct 17, 2020 | 04:56 PM
BLK_EvIL's Avatar
Does the car go into 1-5 fine ?
Old Oct 17, 2020 | 05:09 PM
yes It goes 1-5 fine
Old Oct 17, 2020 | 05:10 PM
hutch959's Avatar
so if your going down the road 50 mph... and you put it in to neutral and let off the clutch... what does it do?
Old Oct 17, 2020 | 05:13 PM
It rolls this is only happens when I'm at a stop it's weird I'm not sure if this is a linkage issue or clutch issue or possibly transmission
Old Oct 17, 2020 | 05:28 PM
hutch959's Avatar
if you are on a small hill. not running in 1st gear... and you push in the clutch, will it roll?
Old Oct 18, 2020 | 02:04 PM
yes the car will roll when you push in the clutch. But when the car is off and it's in neutral the car won't roll if you don't press the clutch in.
Old Oct 18, 2020 | 04:20 PM
hutch959's Avatar
i was trying to see if you clutch was dragging... doesnt sound like it.
doesnt make any sense.
maybe something internal
Khalid
Dec 26, 2018 01:18 AM
DJ Brett B
35
Apr 23, 2014 08:46 PM
5LEEPERISAH23I
14
Mar 24, 2013 01:02 PM
06redrocket
16
Oct 29, 2009 12:40 AM
aguita
Sep 15, 2009 09:42 AM
