View Poll Results: Which one do you prefer?
ShepTrans
16.67%
TRE
16
66.67%
Jacks Transmissions
16.67%
Voters: 24. You may not vote on this poll
Transmission needing rebuild.. Thinking JacksTrans?
Old Sep 23, 2021 | 01:14 PM
  #46
Womb Raider's Avatar
Veteran: Marine Corp
Originally Posted by Panda_Tim
Received your PM -- sent you an email.
Thank you,
-Tim
Tim from JackTrans actually did step in and answer the questions I had for Angela.
I appreciate you reaching out Tim.
Old Nov 1, 2021 | 09:23 PM
  #47
Went out to Fedex today. See you in a couple months ✌🏽
Old Jan 10, 2022 | 04:51 PM
  #48
Can anyone speak of 4.11 final drive upgrade from TRE?
Not really sure if it will be overkill for my level of build.
Old Jan 10, 2022 | 05:16 PM
  #49
CurseDSM's Avatar
Un needed unless your making 700 plus whp. I forget what power level your at and I am to lazy to go back and look lol. I still run stock stuff even with the power level I will be at.
Old Jan 10, 2022 | 05:19 PM
  #50
I'm shooting to be around 450-500whp.
Old Jan 11, 2022 | 01:30 AM
  #51
CurseDSM's Avatar
Only other thing I forgot to add is if you were looking to do a 2.4. the 4.11 would bring your rpms back into stockish range. I know with my 2.4 at 70mph I was at like 3500 rpms or around there. I know the higher hp guys use them but with my new 2.2 I really don't see the need for it even with close to or at 1000whp. Best advice would be to talk to John and see what he says.
Old Jan 11, 2022 | 03:21 AM
  #52
I talked to Aaron at TRE about it and decided to keep stock ratio since im only on fp green and probably wont go big turbo or stroker for awhile.
Old Jan 11, 2022 | 09:01 AM
  #53
LetsGetThisDone's Avatar
Taller final drives should only be considered for high torque cars. Any thing that is still stock engine, or really even less than 500wtq, should stay on stock final drive.
Old Jan 11, 2022 | 12:04 PM
  #54
240Z TwinTurbo's Avatar
You don't need to make 500ft-lbs at the wheels to justify or appreciate a 4.11 gear because there is no magic torque value that makes running a 4.11 vs 4.53 the tipping point for that decision. If you race the car and have certain rpm or gearing constraints then obviously choose your gearing accordingly. Otherwise, for a daily driver the perception of the change is subjective.
Old Jan 11, 2022 | 12:59 PM
  #55
RobbieOh's Avatar
5 Year Member
Is there a chick-fil-a next to this FedEx? It looks sooo familiar!
Old Mar 13, 2022 | 06:06 AM
  #56
BREVO's Avatar
Anyone know of a transmission shop in Maryland that works on EVO transmissions? I need my 2003 EVO 8 transmission rebuilt.
Thanks
Old Mar 13, 2022 | 09:05 AM
  #57
I dont believe so lol.
  #58
Thanks
I sent mine to TRE, and im from Florida.
Old Mar 13, 2022 | 09:22 AM
  #59
BREVO's Avatar
I sent an email to TRE yesterday, hopefully I’ll hear from them on Monday.
Thanks
Old Mar 13, 2022 | 09:28 AM
  #60
BREVO's Avatar
Transmission turn around time.
Jacks 4 weeks
Shep 2 - 3 months
Xshift 3 - 4 months
TRE ?
