wix oil filter help
Old Jan 20, 2022 | 09:16 AM
Wheelspk's Avatar
wix oil filter help
hello,
i just wanted to conform if this wix oil fikter #57092 is the correct oil filter for a 2005 evo 8?
​​​​coz every im confused as if this is for a evo 8 or a evo x
thanks
Old Jan 20, 2022 | 09:35 AM
ronaldo9's Avatar
Yes, there are 2 filters you can technically use for the evo 8. I use this one you are showing. There is a short fat one and long skinny one. I prefer the short fat one for more ground clearance. I also use the M1 108A.
Old Jan 20, 2022 | 09:36 AM
cool_as_crap's Avatar
Yes that is correct, and btw they are on sale for $5.11 on amazon
Amazon Amazon
Old Jan 20, 2022 | 10:48 AM
Wheelspk's Avatar
nice!! thanks guys
Old Jan 20, 2022 | 11:56 AM
240Z TwinTurbo's Avatar
I've been running the WIX 51568, which has a larger filter surface area (177sq-in) vs the 57092 (113sq-in) and a higher bypass pressure at 16psi.
Old Jan 20, 2022 | 07:42 PM
Wheelspk's Avatar
that WIX 51568 looks a bit taller... does it have clearance issues with road road debris??
Old Jan 21, 2022 | 01:34 PM
No clearance issues with road debris or road road debris. Although it's difficult to tell from the angle of the picture, but the bottom of the filter is higher than the mount for the chassis stiffener bar circled in red.
Old Jan 21, 2022 | 10:39 PM
Wheelspk's Avatar
nice ill try this next oil change
Old Jun 22, 2024 | 10:00 PM
sumopower87's Avatar
What is the benefit of the higher psi?
Also, would it make a difference if I'm running 20w50 oil specifically Valvoline VR1 synthetic oil aka smurf blood.
Old Jun 23, 2024 | 09:04 PM
RSMike's Avatar
The only benefit to running a high bypass pressure is it will allow you to catch more debris/particles before the bypass opens.
The bypass does NOT open during normal operation. Only when the filter is full of contamination.
I've already tested this.
Old May 20, 2025 | 11:28 PM
kyoo's Avatar
what oil filter u running
Old May 26, 2025 | 05:40 PM
RSMike's Avatar
I've tested a bunch. Wix, Ryco, OE Mitsubishi.
Currently i'm running the OE Mitsubishi oil filter on my car, they are easy to get an reasonably priced.
Blacksheepdj
Lancer How Tos / Installations
Nov 23, 2007 09:26 AM
Mach 8
Oct 2, 2004 10:42 PM
2BARevo
May 3, 2004 03:50 PM
lanceryellow
Apr 18, 2004 11:17 AM
cecilia
Apr 25, 2003 10:21 PM
